Nah haven't got one. Take it down the strip soon and I will see what mph it pulls. That will tell me what power it puts down. Old school way and most accurate IMHO.
I was more after the shape of the curve.
Still good, be interesting to see what you pull
I think the -9s on e85 would be whey better, but then again I've been in very quick sr20's and 4g63's, so I know what instant torque on tap is with a 4banger. Once u go torque, u never go lag again
'Instant torque' how instant are we talking with the -9s? Are they known to pull all the way to redline? With a new set of cams that is..
some of the guys with that setup could tell ya more regarding that, but more importantly whats your budget?!
These days 34 GTR N1's can be had for 4 cheap! I'd be focusing on that with the e85 and the cam gears with the tuning!
No need for cam shafts until later if ever
Does anyone know how fast i'd be be going if it took me an hour to get to my destination and the distance was 100km?
^^ Is this a trick question? lol
-5's on built engine with E85 would be the way i would go and if it is in the budget get the 2.8 as it would make them that much better. Here are 2530's (-5's) on a 2.6 with E85. Compare this with other set ups with a 2.8 and the difference is night and day.
Couldn't find the one with RPM.
King87 u made 150hp@ 100km/h = winning.. awesome top end tho! But in all honesty wouldn't 2530's be better suited to a 3.o bro or 3.2/3 for the street?
By the mph about 240kws at the wheels
I'd say 240.318kws @ the dildo shifter to be precise
Edited by discoPumpkin
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
