I would have gone for a dual plane element version had one popped up, but as I wasn't about to spend $2500 plus on a wing I took what was available in the right sort of sizing for the car, in excellent condition. Most wings were too small. I was also quite set on either the C-West or Voltex as I wanted something proven, and the Voltex popped up first.
I actually used to have a dual plane C-West but in aluminium. I was defected my first week of having it on so I got rid of it! It was also a bit heavy, noisy and not wide enough.
With the correct front bar with dive planes, mated to a nice undetray, chopped rear bar with diffuser I think it would make meaningful gains in cornering force - but what do I know! :whistling:
Something like this:
  • Replies 105
my car is alot more well behaved now with the wing on, most noticably under heavy braking.
i got this gt style one a while ago now, but after reading info off this thread.
as stated by others, a wing is a bandaid for other setup issues sometimes, best to develope suspension before adding wing.
if only i listened to that advise lol.
What width and height Adz? I am expecting that the R34 GTR wing I am running to be inferior to a wing like yours...so doing a bit of homework in case i need to buy something.
In regard to height, with my very limited knowledge of airflow over the roof of a car a rear wing should be level (or close to) with the roof line in order to use this airflow. Adz's above looks perfect.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
