im sick of customers asking for swimming pools i was getting about 20 a day, also people were buying the biggest ones which hold over 16,000 litres and im pretty sure you need a permit to fill up something that big but i bet most people didnt. :ermm:
  • Replies 103
your legs make a peeling noise every time you get off the leather seats.
when you go to the beach and your feet sizzle on the sand.
when you fall asleep in the water lying on your back, floating around in the shallow knee height water and wake up in water up to your tummy.....
oh and when your naturally tanned, but you still get phucking burnt!
when you tight ass Indian parents come to you and say
*in an Indian tone*
"son installing the AC in the house was a brilliant idea, fantastic"
hahahahaha
i almost fell of the chair when my mum came up to me and said that
"It's Mind Blasting!"
when thousands of ants thinks its a bloody funny idea to infest your car interior and exterior, forcing you to emtpy half a can of Raid inside your car (leather and woodgrain 'Smelt' nice). now just smells like raid.
dont feel like using the A/C no more, incase i get a ant shower !!!!!
yeah, but its the western suburbs
>_<
Lol harsh.
My power is yet to go out...
The same can't be said for the whole of Crown last night however...Wouldn't want to see the amount of money lost by the Casino alone, not to mention every restaurant and store in there, as well as every Crown car park...
Yeah, a lot of people had to line up to get refunds, as their change was in the pokies when they konked out.
when you find a KOALA having a BATH in a tub of water you left lying around.....
That's awesome... ...and cute... ...and looks so tame...
I've always understood that koalas never drink water because they get all they need out of what they eat...
yeah but they only leave the tree's if there desperate. out of food, then get hit by cars .
this one tooks its chance's and but it aint looking back :)
here's a link to a koala drinkin from a hose due to the heat wave
http://au.youtube.com/watch?v=mz6fwDph8wQ ....
Wow that's cool! You must live far away from the city?
I guess not even eucalyptus leaves have much moisture in them during the heatwave. I'd be friggin hot too if I had an inch of fur covering my whole body and no sweat glands.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
