Decided to put my Z32 afm back into the 34.
I've tried the 'do it yourself' threads but they mainly outlay 32 and 33's
Similar I know, but I want it done right.
Ive read I have to solder the wires back. Anyone have experience with soldering kits ? howmuch are they worth ?.
(Woulda put this in wasteland, but it would have been swamped with crap)
https://www.sau.com.au/forums/topic/255354-z32-afm/
I like trying things out myself.
If someone has done it before I could learn.
boostworx would cost me $70 in petrol to drive all the way down there lol.
any mechanical shop can help you in that...
morpowa are up north mate why not check them out
see simon in person and you might get it done for cheaper as well
https://www.sau.com.au/forums/topic/255354-z32-afm/#findComment-4404703
Aren't you up at windsor gardens
well my advice is find out what the original wire's do and which order and find out for the z32 which you will have to get the wiring diagram for a z32 300zx
make sense
Yep. makes sense.
Yep. Pretty close to windsor gardens.
I've seen pictures of the wiring setup. How easy are soldering kits to pick up, though ?
Yeah cheers. Forgot about them.
If I cant figure it out myself I may pay morpowa a visit.
Does anyone know what a soldering kit is worth tho ? and where I can get one.
https://www.sau.com.au/forums/topic/255354-z32-afm/#findComment-4404728
Go into Dick Smiths mate and get one
dont exactly know the price but wont be much more exy then $50 for a ok soldering kit
https://www.sau.com.au/forums/topic/255354-z32-afm/#findComment-4404740
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
