i got afc analog one with the knob would that affect anything and i never noticed it before as it never ever did it i notice it in the passenger side mirror are you guys sure this is safe.
also really dumb question how do you guys put those movies and pics under your user name
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543066
The one knob AFCs are essentially useless. I'd say I'm almost 99% sure that's what is making you run rich and causing the smoke. They only allow you to add/remove fuel across the entire rev range, so you cannot fine tune it. So if you are adding 5% fuel at 5000rpm (just as an example), you are also adding that at 1000rpm. Not efficient at all. To be honest, I have no idea why Apexi made it.
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543528
I got greyish smoke too :P
A couple months ago the engine made tapping noise which sounds very very similar to my old Mitsubishi Galant with valve stem seal problem :( unlike my old Mitsu where noise is still there all the way, in my skyline the noise is gone when engine is warm
But after detonation problem on a recent cruise, the cold start tapping noise is gone and hasn't come back since.... wtf????
Must be something else...
turbo seal on its way out?
is that tapping noise = turbo wheel touching its housing?
that detonation (due to over boost to 15psi) could have chipped the wheel edges so it no longer touch the housing?
I'm sure exhaust wheel still there, car can still make that much boost over 10psi (but I've turned it down to 8psi since)
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-543543
Originally posted by rs73
I got greyish smoke too :(
A couple months ago the engine made tapping noise which sounds very very similar to my old Mitsubishi Galant with valve stem seal problem :D unlike my old Mitsu where noise is still there all the way, in my skyline the noise is gone when engine is warm
If the turbo wheel was touching the housing it would whale/howl not tap.
I would actually see a mechanic and do a compression test, amounst other checks.
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-544637
hehehehe , try this go downhill a very long and steep hill stay in 4th or third gear do not touch the accelerator untill u get to the bottom when u get to the bottom of the hill eccelerate look in the mirror for smoke if u see blue smoke its u r valve stem seals . if it blows blue smoke under hard ecceleration and or high revs then its piston rings . just black smoke running a little rich but u'll get more at high rpm if running rich .
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-544711
Al,
My turbo squeal like a mad pig on cold.... is that normal?
When warm it doesn't....
Anyway my car is now in the "hospital" now... hopefully
nothing serious...
https://www.sau.com.au/forums/topic/25545-some-smoke/#findComment-545055
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
