Welcome to the forums
Deca - http://www.skylinesaustralia.com/forums/Mi...ot-t255432.html
SAU Vic Renewal/sign up dyno day - http://www.skylinesaustralia.com/forums/Sa...no-t255356.html
If you sign up before the 8th, you could come on what is going to be an awesome members only cruise :D
There's a link to the online signup form in my signature below ;)
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406827
If you sign up before the 8th, you could come on what is going to be an awesome members only cruise ;)
There's a link to the online signup form in my signature below :)
Thanks Dezz
what time is the cruise on the 8th, as I got work and don't know if i will be able to make it.
also if i come to the sign up day with a filled out CAMS License form, will that be processed in time for the 1st DECA
Cheers :D
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406911
Thanks Dezz
Cheers :D
The cruise on the 8th is a members only cruise, so can't really give away any details...it begins in the morning and will run all day though..
As for DECA/CAMS, you can hand in your completed CAMS form along with the correct money on the day at DECA, and you'll be fine to compete. However you'll need to be a member of the club (or another CAMS affiliated club) to obtain a CAMS license. Otherwise you can get the AASA license instead.
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4406951
Thanks everyone
I guess I won't be able to make it to the cruise on 8th anyway as i work from morning to after midday, so I'll try and attend the sign up day on the 21st and sign up there, hopefully it will still be running at 3pm as i finish work just after 2pm.
Might try to get out early to make sure I make it. :)
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4407098
Thanks everyone
Welcome mate..
Hope to see you at the Dyno day..
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4409310
Thanks for the welcomes everyone, I will hopefully see you all down at the dyno day
Hey man welcome
nice car!.. you wouldn't happen to have been parked all day on stanley st in west melbourne today?
Nah that wasn't me, I saw what looked to be an identical 180sx to mine in tha dandenongs though
Welcome aboard.
im planing on being at the dyno day myself, hopefully will see you there...
nice car by the way, i very nearly bought a 180sx myself once. ;)
Hopefuly see you at the dyno day.
What stopped you from getting the 180?
Can we Originise your 180SX?
:happy:
I would love to Originise my car, but right now I am a little short on money as most of what i saved went towards buying the car itself
How much is this kit anyway?
https://www.sau.com.au/forums/topic/255502-hey/#findComment-4410103
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
