ok i just seen that my inner front cv joint boot is perished away and i can now see the bearing, anyone no where i can get a replacment asap.
i looked at these boots that split apart so you dont need to remove the axles to fit, but not too keen on em but if anyones used em and they seem ok ill use whatevas goin.
https://www.sau.com.au/forums/topic/256272-cv-boot/
This guy sells the complete cv joint for less than Nissan charges for the boot. He may also be able to supply the boot only. Send him a question quoting your engine no and other details he asks for and ask if he will post to AU. (if he doessn't but he has the item I could get it for you and post it but i am hoping he does because a number of other members have indicated interest). http://www.trademe.co.nz/Trade-Me-Motors/C...n-201624551.htm
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4417885
  • 7 months later...
Hey Guys I have just replaced my front boots with local Kelpro units at $15ea.
Part no':
Inner: CIB-228
Outer: COB-057
Only point I would make is that there is not enough grease supplied for the inner if you ask me, so grab some extra.
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4849949
Part no':
Inner: CIB-228
Outer: COB-057
how would you rate the difficulty of the job mate? i've never done cv's before, but will probably be looking at it in the not too distant future ;)
Edited by pyro-ns
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4850408
Ok Guys its all pretty straightforward to do, probably the only special tools you need are circlip pliers and a vice is handy.
Firstly remove the shafts, there is a good description here on pages 10 & 11
http://www.scribd.com/doc/4964854/GTR-Engine-Removal
You will also need to pop out the cup that is in the diff housing, a couple of large screrwdrivers should do the trick (carefully)
Next I usually cut off the old boots and give the shafts a good clean ready for new grease & boots.
Below shows the drivers side, the passenger side should be similar (I only needed to do my drivers side, but the passenger side looks to be exactly the same procedure). :whistling:
You need to remove the circlip that holds the bearing assy (part A) to the shaft (part B) in the pic below.
Remove part A from the shaft and you can now slip on your new boots.
Replace part A and circlip (grease the splines) and complete assembly as below.
This is just a matter of packing the bearings and cup with grease and fitting the new boots. Make sure there is no grease on the part of the boot that will be clamped to the shaft & cup (under where you tighten the stainless ties).
Tighten the stainless straps by stopping them rotating with a flat blade screwdriver whilst gripping the strap with locking pliers. Bend the strap over once, bend down the tabs to keep in place, and bend once again over the tabs and cut off the excess.
Reinstall the shaft in reverse order of taking it out.
I think this covers it if you get stuck on anything let me know.
Hope this helps.
Good Luck,
Jon.
  • Like 1
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4864108
Thanks for posting that up mate :(
So after doing this im going to need an alignment by the looks of things yeah? When i got the outers on each side done previously at a mehcnaincs they said they do it so it didnt need an aligntment.....
Ideas?
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4865006
Thanks for posting that up mate :P
Ideas?
In theory it shouldn't need an alignment as you're not actually adjusting your tie rods, just disconnecting them to remove the shafts and putting them back. Unless you have some really worn components, they should bolt back up in the same position they were in.
However I reckon it's always a good idea to have things re-aligned when you've done any suspension or steering work.
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4865779
Well im preping to do this in the next week or so. Wouldn't mind doing it tonight but I need to use the stag to go jetskiing tomorrow so might noit be a really good idea incase i dont get it back together... dont see why i wouldn't though..
Went to see my local repco for the boot. Qoted the Kelpro CIB 228. He matched it to a Repco unit they had in stock part number 100-039. Comes with straps and grease. Cost me $13.60 with my trade card.
Will post up how I go and might ask the woman to take photos while i do it so i can make a how to however i dont think shell like the idea of it.
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4870992
Good luck with the boot install. Let us know how the Repco unit fits, it's good to have alternative boot options that don't cost $100 or so each from Nissan!
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4875746
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
