Here a tip. My Fiance says if you buy a $100 coles gift card it is all profit as they don't have to pay for product to sell, so Fire appeal gets $100 you get $100 gift card you can use to pay for your shopping instead of cash, then fire appeal gets another hit up of profit cash from your shopping!
Makes sense but not sure if gift cards are classed in this thing or not.
lol i dont think it actually works that way
Lol, neither do I, but it would be cool if it were true.
our work donated 100k and we have a fundraiser today as well and our HR dept has arranged for special payments to be arranged from peoples wages (whatever people authorise to be taken out (1 hours worth of wage a day or at whatever people specify) pretax to be donated.
We'll go to the coles one this Friday, then to the safeway one on the 20th plus donate about 100 cash.
every bit helps
spent $150 on friday night at caroline springs coles
also took me the missus and 3 friends to bunnings and made them all eat sausage sizzle from there as weel because the cash all goes to the bush fire thing . . . . . and any excuse to go to bunnings lol
We hit the local Coles, queues were big but am sure it was worth it. Will be great to get a final figure as so many other people were there for the same thing. I also set a deductions scheme out of staff pays at work too, either once off or payment reducing over 4 weeks. All for a very worthy cause.
I worked 9 hours at Coles on Friday and it was absolutely hectic. Worse than Christmas or Easter. Basically all the staff were at the service area all day, regardless of what department you were in. People went nuts too, bought like 5 years supply of tooth paste, etc. Saw several ~$1000 orders go through my register alone. I work at one of the bigger Coles stores, with 13 registers, and every single one (excluding the 3 express) had at least 10 trolleys lined up.
I will say this though, despite the monster lines that filled the fresh produce area, blocked the deli off and forced people to wait nearly half an hour to reach the register; no one complained. Everyone was in good spirits, polite, friendly and patient.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
