Ive been looking around for a skyline atm, heard different stories from people about how costly they are to run? if im not drifting dragging etc, i dont imagine itd be more then the normal car just for little things needing replacing here and there? or am i wrong?
cheers
https://www.sau.com.au/forums/topic/256790-skylines-a-good-reliable-car/
  • Replies 41
Get a tidy low K's Skyline and it wont be expensive to maintain.
Get a High K sh*tbox that has had the Ass Caned out of it and watch your cash vanish into thin air. They are fairly robust things but Any car whether it be a skyline or a ferrari can be a lemon.
Yes and no. They are getting a bit old now so things like bushes etc are gonna need to start being replaced, other than that I haven't had an issue with mine. Same as any other old car. Fuels the biggest one, its not too bad usually about 10.5L/100km unless your heavy on the go pedal then it can fluctuate as high as 13L/100km
Bought R32 GTST straight out of compliance, about 7 years ago.
Regular mtnce ( inc things like Spark Plugs / Timing belt ). Accessory type trouble only, like radio and some air-con probs.
Could'nt ask for better trouble free motoring.
I don't thrash it, and I don't nurse it.
I agree with the Yes / No
all depends on the cars service history and what its going to be driven like with its future owner!
Word of advice, if you buy one 'dont boost it up' cause they last longer like Jax said
i had no problems until some nub tuner boosted mine up, pretty much died in a month
Ive had mine 4 years and all ive had is a hole in a clutch line. the car is coming onto 15 years old now and still in excellent condition. like to see how a 15 year old commo or ford looks.
Edited by Pal
I replaced my clutch with a HD item and subsequently had the clutch pedal bracket snap, so replaced that.
Now I'm looking at replacing front CV joints and my bushes. Other than that no problems with it.
They really aren't that bad until you modify it, if oyu don't do the supporting mods then things will start to fail.
lol as high as 13/100kms .. I WISH. My r34 GTT drinks 16.5l/100Kms in city driving and that's not racing or being an idiot ..remapped ecu so its not running rich either. Original O2 sensor but its not showing any error codes - oh yea BP Ultimate only.
I got my 34 gtt and it had low Ks and was stock completely .. and Im starting to think it was a lemon, spent more than 2-3k in repairs alone in less than a year and now I've got whining/feedback through my steering wheel accompanied with loud scraping when I turn the sterring wheel... f**king getting tired of it.
Edited by Delta Force
Had my skyline for about just over a year now (bought it back ~ Dec 07), bought it as a stock one & I left it pretty much stock & had no problems with it other than the problems that it had when I bought it which was a broken A/C & cigarette lighter not working.
& I didn't really give it any special treatments, just do the standard service every 5000km & had the major one done @ 100,000km. Oh & I wash it occasionally when I can remember.
Fuel wise it seem to stay around 13 - 15L/100km but thats mainly city driving with alot of short trips & getting stuck in traffic @ peak times :D
Edited by Mayuri Krab
I have had my modified GTT for 2 years imported myself, had mods in Japan very tasteful and the guy seemed to look after it well. I have always given all my cars what for :( but i am very anal about servicing and i have never had a problem with any of them, it all come to maintanence and the right quality for the car and you wont have a problem.... Also get the right tunner to tune it if you want to power it up a little, i run 14psi off the stock turbo and never had a noise or problem...
I ran my R32 GTSt for over a year with an untuned 250rwhp, only issue I had was on the way home from a cruise one day I snapped the clutch fork pivot >.<
Was super fun, went hard and took a LOT of punishment.
Then I decided to get a little more serious :(
They are as good as any car.
The owners both present and past determine reliabillity.
What you do to the car , how you drive it
I would normally get 10L or better per 100km out of the old R33 gtst and similar with the R32 Gtst and R32 GTR's.
The tune and type of mods you do effect things, like any car.
Things like not going for super heavy sprung pressure plates in the case of clutches in R32's will prevent braking pedals etc..
There is plenty of good info on the forum about it all
If you are thinking you want to race and modify any car, then just throw your dreams of reliabillity into a nearby bin.
Well considering the stock GTT turbo is rated at 12.5psi MAX I'd say you either have a highflowed turbo or a non stock turbo or a BLOWN turbo and you don't even know it ;-) I'm yet to hear of anyone running more than 12psi on a stock gtt (non-hiflowed) for more than a little while without blowing it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
