  • Replies 2k
In the engine bay, next to the firewall??????
If you are above it looking over the o/s/f guard and it sits below the light relay on it's own, like at the bottom below 2 other relays, you don't need it unless your an AUTOMATIC (heaven forbid matthew) because it's the inhibitor relay, according to the manual.
But if you are looking at it from the n/s/f guard and it has some wires connected at the side of it, it is the horn relay.
Does this help?
You should have a manual, I got a spare that I got with my car if your interested. :ghost:
i have a manual for the mr30 which is an auto, the other thing is i have the fuse cover for it but its in japanese?? the english version for the mr30 states its an inhibitor relay for the auto mr30 thats why i had to ask as the 2door is and was a manual, in short what your saying is that its nothing to worry about?
i'm doing a trial and error to see why the lights and indicaters are not working, will be replacing the indicator stalk tommorrow as i think this is the problem!!
thanks anyway ghostrider!
If your using high power globes, you have probably burnt the contacts on the switch, or somebody has at some time.
I have, an extra loom that came with my original iron mask front cut, an extra loom just for the lights.
It draws power from the main circuit breakers, but has a 30 amp relay for each globe and the loom is about an inch thick.
But the globes I'm using are the latest & greatest from IPF in Japan. Mains 55 W input/ 145 output and high beam, 80W input/ 165 output, but still using the extra loom to be safe.
http://www.carsales.com.au/pls/carsales/!c...rch_distance=50
interesting......
found this r30 while looking for a Calibra on carsales.com
since when have skylines been 4cyl-i thought there were only 6cyl?
anyway check it out... :rolleyes:
nicko in my work i drive around in a yellow van with flashing lights on the roof that comes to help when your car breaks down.
In my work you quickly learn which cars are reliable and which are not.
My advice would be to not buy a Calibra,Astra,Vectra etc etc.
Ghostrider are those headlight globes the blue tinged ones you see on some late model beemers and such?The extra wiring/relays is a good idea with brighter globes.(watts divided by power(12v) gives your current draw).Most of the factory relays are not able to cope.
Do you have any pics of your 30 for all to see?
Regards Todd
Can anybody tell me What is the AFM in my mR30 and where is it, should i just take it out to get better proformance and what is the ECU. and how do i put a resitor in between the AFM and the ECU. Also would a RB30 coil do any good in a MR30
Thanks again josh
The AFM is located at the bottom of your airbox AND I would be very surprised if it went at all! without it.
The ECU is located in the passenger side inside kick panel and it is Engine Control Unit and without this, IT NO GO AT ALL.
Forget the resistor, you get suckered into buying the 20Kw performance pack on ebay????? They only work in temperate conditions, if like today, "a stinker, HOT HOT HOT. it won't do anything more than eat a sh#t load of fuel.
As for RB coil, don't know, ask an auto electrician, but if it's the bosch coil, can't see a problem, but difficult to use the EFI coil packs. :ghost:
Thanks again josh
looked a little harder for you about the msd coils, what you need to be asking about is the msd blaster coils as the other ones they are trying to sell you are a individual coil per cylinder and far to expensive!!
question - for the firing order on an rb20, how do i run the leads to the coil packs.
is it sparky one to coil one, s2 to coil 2 etc...
or is it sparky 1 to coil one, sparky 2 to coil 5, sparky 3 to coil 3???
assuming the firing order to be 1-5-3-6-2-4
if anyone understands what im rambling about
yeh and the resistor thing that you speak is as ghostrider said a slight waste.
my AFM was adjusted internally at the flap by Datrally in melb and they spent a long time doing it and many dyno runs till it was right not something you should really frig with especially when you don't even know where the AFM is on your car
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
