I'm going to have the same problem, as my R33 gearbox mount is about 150mm further back than standard.
I am making a "C" type mount that carries the original g/box mount on a box section piece of RHS having about 4 mm plates going back to the original mount points braced with a web section fillet.
Just have to get under it and design it, put it on paper and get someone, any welding/pressure vessel shop to make it for you. About any Sheet Metal/Engineering Shop will be able to point you in the right direction if they can't do it themselves.
ok, cheers for that mate, ill let you know what i come with :D
i also thought about dropping bolts through the floor so the mount lines up with the xmember... ?
  • Replies 2k
If you do that, make sure the holes are reinforced, because with continual driving and some hard launching, they will tear out of the floor, making a bigger problem than the initial one you have now.
Might be better to use the orig and mount back to them
ANYTHING will fit if you try hard enough.
I put my SAAS seats, on a piece of 12mm aircraft grade aluminium sheat and then mounted the runners to the same sheet, that way I still had some adjustment front to rear.
I removed the height adjustment as I needed to lower the seating position about 100mm to allow me to sit in the car with a helmet on.
I am going to experiment with R31 seat tracks, as the height adjustment is on the track and not in the seat.
I have a set (pair) of Z32 import seats if anyones interested, they have a fully electric drivers seat. forward & aft, height, lumbar, and wings. Would have to make up mpunts as they are a very narrow seat.
Mike,
Do you presently have DR30 rear brakes?????
If yes! they are identical to Z31 300ZX rear rotors.
If you don't want to buy NEW, find ANY wrecker that has Z31's.
Are the rear z31 calipers similar to DR30?
Mike Cash - how did you go getting through regency?? or have you got any more info on what you would need to do?
ghostrider: im assuming that z31 rear dics would be the import old rb20 z31 or the aussie one, or are they the same size?
nah i got the dr30 rear end on mine at the moment and my dics are undersized from ever use.
as far as regency goes, aparently all you need is the same dics size as a car that had an rb20det. in my case i used r31gts fronts and dr30's rear and other cars have been passed without any engineering certificate or anything.
Will S13 seats fit - i got a set for free.
Measure the rail spacing. I measured a set up for my R31 (which may or may not be closer in design) and the S13 rails were about 45mm too far apart - the R31 centre to centre of the rails was 415mm where the S13 was about 460mm.
What or how do you call an DR30 HEAVY???? What are you comparing it to???? Maybe compared to a Mini, but to another Skyline, it's one of the lightest. DR's max weight 1250Kg, R31's OZZY sedans 1600Kg, HR31 coupes 1350Kg. How you say heavy????
WHOA! where'd you get that weight from for the aussie R31!?!?! I weighed mine with 40l of fuel, spare, tools, jack, assorted crap and full trim and it was 1280kg on an extremely accurate weighbridge. Mine is a "stripper" model GX though, with no luxo bar power steer and aircon, with basic trim, and its manual.
All reports I've heard peg the HR31 at closer to 1400kg, on the + side....Especially for the sloppy fat bitch Passage's...
my epic adventure is comming to a close, pick up the rims with new tryes tomorrow morning went for falkens ze512's 225/50 on the rear and 205/55 on the front, pick up the front seat, new tacho and boost gauge on sat then its fix the lights and shes ready for engineering!!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
