I got a stock one, but otherwise get it made.
Your sedan got rear discs with it's IRS???
All hatch's have rear discs and they're interchangeable with sedan. Just attach at cross member, but if you do this you will need the handbrake cables as they are different to the drum ones.
nah got me a dr30 rear end. disc, calipers, shafts, everything except diff
  • Replies 2k
r31 gts front shocks etc with discs and calipers
rear is dr shafts (i think) but an r200 open wheeler which has stood the test of time for at least a year of second gearies
Same spec, just different offset on hubs.
Is yours pre or post 83?
82
You would have a TOKIKO style master cylinder???
If yes, there is a 1 inch upgrade available, don't know what vehicle it comes off, but if you took your old 7/8 m/c to a brake shop, or you know exactly what it looks like, get them to order you one.
Our 84/5's can only go up to 15/16 unless we change all the bundy tubing.
im not sure. the cylinder seems to be holding up ok so far. what are the advantages of changing it?
makes sense. z31 discs are the same as dr30's?
Same spec 274 x 22 as your R31 GTS.
We have discussed this topic extensively on another thread.
I have DR front & rear, slotted rotors and EBC green pads up front & black rear.
They are a high temp KEVLAR compound low friction, excellent road set up. But I am going to upgrade my fronts to BNR32 GTR 296 x 32 with 4 spot Nissan alloy calliper, only because I have, potentially over 300Kw at the wheels.
Anyone know if cutting a MR30 hatch grille (the eggcrate one with the three slats) so that the eggcrate crap comes out, effictively makes it the same as the other three slat grilles?
And if a set of coilovers were made for a 180B, they should bolt up to a R30 since R30 stuff bolts up to Dattos?
when i did the engine swap the machanic put the r32 master cylinder on mine, never had a peddel feel so good! with the hr brake callipars on mine i had to go to bendix comp X pads as EBC dont make front pads for these callipars...
Jenesis is www.r30.co.jp but when you access it put it through Alta Vista translation or similar so you can sort of understand what there saying in descriptions.
BUT! don't get to excited, they won't trade with you DIRECT, it's a good site to explore, and a lot of their parts can be made here just from the pictures. It is a good referrence site as well, to see what they do with them in Japan.
If your interested in getting some bits from them, it might be a good idea to put it to open forum discussion and we try and jointly get an order together and then get in touch with a parts importer, like Nengun, one of SAU sponsors.
Only one problem I can see with your car...... far too many doors!
i'd put my hand up for a group order from jenesis as there are a few body parts i'd like from them, i could speck to the boys at option 1 as they have have containers comming over each month...
Already done that, I talk to Nathan & Paul at least once per week.
Yeah i would be interested as well in getting some stuff from jenisis...I know in one of the earlier pages on this mammoth post that there was talk bout it, but that kinda died in the ass i spose...I wouldn't mind some of that bracing for a start that would rock!! Depending on what we can get and for what sorta $$$ it will all cost of course though!!
Geez,you've gotta be on the ball to keep up with this thread!! :D
Talk to Whiteline and they will tell you both rear tower brace and floor braces aren't necessary' date=' but Jenesis makes, sells & uses them, so! someone aint up to speed.QUOTE']
I thought it was still a good idea,even with a rear tower brace,as the mid-section can get a bit "flexy" with no B pillars...
Also,I may be interested in a engine dampener brace from Jenesis,depending on price.Does anyone know if there's something to do the job locally?
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
