boost is not related to stock coils keeping up or not
they simply die of old age
so you can run 27psi if you like
one day they will die and misfire regardless of engine boost
once the engine is on load, it will misfire
so run whatever you like
1.3kgcm2 if you want
the turbo is a high flow, the ecu is std but has a haltch intercepter connected which has been tuned, The engine has forged pistons. Im guessing the coils are as old as the car. Someone told me it could be the higher boost is blowing out the spark?
breaking down spark is different to coils dying
coils die due to age, when they die, like i said, they misfire as soon as the engine is on load
ie one day its fine, next misfire city, so its all of a sudden.
spark breaking down is usually too much boost or wrong gap or intake temp too high
or combination of all three usually. if running less boost cures the misfire its probably spark breaking down
my coils lasted 160,000 then gave up
In my experience the typical coil misfire is the insulation giving out, everyone I know who has put work into decently re-insulating them have fixed it fine. I run up to 18psi on my original S2 R33 coils with extra insulation on them is going fine :(
Yea it happened really bad one night when the air was still pretty hot. I found a few FAQ's on how to insulate the coils, So i might give that a go and replace the spark plugs. What better out of BCPR6E or BCPR7E? Or do people recommend any other ones?
who can repair coils?
I have splitfires in mine atm, sometimes when I leave car to warm up in morning, it will run on 5 cylinders, ill go out, disconnect connection to coil #3, plug it back in and away it goes back on 6 cylinders.
But when I drive and give it a little stick, it starts miss-firing so i assume its that faulty coil?
the 10+ year old plug or wiring is likely at fault vs a new ~ish splitfire coilpack set
You can also get the coil pack loom from Nissan for around $140AUD from memory... its pretty cheap if the plugs are a bit stuffed.
I purchased new for mine with the splitfires, good insurance.
And for the record i made 370rwkw on stock RB25 coils, they were in very good condition :D
yeah...quite a high price..it might be better to find a private seller they might charge 30 bucks or lower.
A private seller for a coil harness?
I paid $120 for mine from RHDJapan, with shipping it worked out to the same as getting it from Nissan but got it in one week instead of three. I looked up the harness on RHDJapan recently and they're up around AU$270 delivered now :)
I was troubleshooting a misfire when hot issue for AGES, turned out it was the insides of the coil harness plugs falling apart.
I meant quite low price considering…
Why get one 2nd hand for $30 only to have the same damn problem 6 months later?
Makes zero logical sense. You cant get them much cheaper as bubba has pointed out :)
Pay the Nissan price, its actually reasonable in price for something OEM and after 10-15 years does need replacing
  • 1 month later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
