car info
TUNED BY STATUS TUNING
302rwkw at 1.5 bar car makes full boost 1.5 bar at 3,900rpm
all wiring has been cut to size, to ensure no eletronic problems
i am the vic motul rep so only motul oils have been used throughout the car.
1999 Nissan JDM silvia
79,xxxkm
Engine:
SR20DET
Trust Td06 l2 20g
Trust high mount manifold
Trust 48mm external gate
Trust dump and front pipe
Trust sump
Blitz pod filter
Nismo engine mounts
Ikeya formula intake plenum (quad throttles)
Ikeya formula fuel rail
Tomei rocker arm stoppers
Tomei 1.2mm head gasket
Tomei head studs
Tomei pon cams 256in 256 ex
Power enterprise 800cc injectors
Greddy pully kit
Trust 13 row oil cooler kit with remote mount
Trust LS front mount intercooler
Fwin dual layer radiator
SFS radiator hoses
R33 clutch fan
Trust petir titanium cat back
Apexi evc
Nismo intake fuel pump
Split fire coil packs
Trust oil cap
Cas cover
Sard fuel regulator
Speed flow fittings and braided lines
Drive train:
Nismo 6 speed transmission
Nismo super coppermix clutch
Nismo lighten flywheel
Nismo GT LSD
Trust diff cover
Wheels:
Volk 57s pro
18 x 9 +12 toyo t1r 225/35/18
19 x 9.5 +12 ironman 235/35/19
Trust wheel nuts
Brakes:
r33 gtr brake master cylinder bm57
Front
Trust front 6 pot callipers
Trust 355mm rotors
Trust pads
Trust braided lines
Rear
R33 drum handbrake conversion
Trust 4 pot callipers
Trust 330mm rotors
Trust Braided lines
Electronics:
viper 1002 alarm
Apexi power fc d-jetro (map sensor)
Blitz id-3 boost controller
Defi control unit 2
Defi oil temp gauge
Defi boost gauge
Defi exhaust temp gauge
Greddy incabin damper control
Suspension:
Greddy type S coilovers
Nismo front strut brace
Nismo rear strut brace
Nismo front lower control arms
Nismo rear lower control arms
Nismo front sway bar
Nismo rear sway bar
Uras front cast rods
Tien tie rods
Cusco rear camber arms
Cusco rear toe arms
Uras rear subframe bushes
Body:
Full genuine Vertex lang kit
Resprayed in house of kolor white with white candy
Spoiler holes removed and de badge
front and rear guards flared
Interior:
Bride zeta 3 driver seat (red)
Bride zeta 3 passenger seat (red)
Bride driver sl seat rail
Bride passenger sl seat rail
Bride door trims
Nardi deep corn steering wheel
Nismo gear knob
ENJOY
also car is for sale !!
Edited by 180athid
https://www.sau.com.au/forums/topic/257679-march-fast-fours-my-car/
  • Replies 44
Posted Images
very nice mate.. surely you can keep it and buy a house aswell... you wont get what its worth so you may aswell hang on to it... these days you can get a 95% loan anyway.
and who is the fast fours photographer... they always have good photos.
cant beleive you are selling it already athid... it was only a year ago that you were soooo excited about getting it...
hell of a lot to do to a car in a year aswell!
gl with the sale :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
