I don't think there will be much in the way of results... the only way to do it properly would be to have O2 sensors in each exhaust runner and test back to back to the stock RB26 plenum. The aim of the plenum is to achieve equal flow distribution, there will be a small power gain because of the increased volume.
  • 9 months later...
Hi guys,
Just digging up this thread for the benefit of anyone who is considering using one of these.
I aquired one from a mate who is parting out his race motor - never intended to buy one due to the price but I got a sweet deal.
I was expecting more low end torque and a significant power increase.
Very hard to compare todays dyno result to last time as the air temp between winter and summer is so different along with air density.
Anyway; basic motor spec:
RB26 bored 0.5mm
Ported cylinder head
Tomei 270/260 Pro cams (I think)
HKS GT2530 Kai's
Factory cast iron manifolds.
1.7 bar boost.
No other changes other than the Nismo plenum and the weather conditions.
Previously made 620nms at 5,100rpm and 467kws @ wheels at 7,200rpm (DIN).
Today made 610nms @ 5,100rpm and 473kws @ wheels at 7,800rpm (DIN).
Power used to drop off sharply after 7,200rpm but now its flat all the way to 8,000rpm.
Boost curve is around 100rpm slower to build but still peaks at approx 5,000rpm. It has less "spool" from 3,000 to 4,000rpm but climbs much more steeply from there. Boost curve is more stable than before as it used to dip down slightly between 5,500rpm and 6,000rpm. Now it sits flat to redline.
We tried more boost but the EBC couldnt control the boost steadily over 1.7 bar so we stayed at this level.
My conclusion is that its a worthwhile mod but perhaps not so useful on this particular spec engine.
Pro's: wider power band, more stable boost, more even cylinder temps at #6.
Con's: price unless you get a good deal.
Just bare in mind the plenum may work better or worse depending on your engine spec. Happy with the stronger top end but somewhat dissapointed I didnt get the torque increase - maybe just the weather??
Cheers
Andy
Thanks for the results Andy - fits perfectly with the 2% quoted by Nismo, given its pretty much what the results show there :thumbsup:
Boost stability should'nt change with a properly sealed plenum.working EBC be it Nismo/Greddy or stock - so it sounds like the EBC (or whatever method), something has changed there. Perhaps a slight leak with the old plenum.
It's funny that in RH9's case the peak torque was slightly less at the same RPM when the runners are longer and 2 mm smaller.
I know years ago, Yavuz spun mine to 9000 RPM and power held flat. It didn't really "nose over" as such. Hmm..
Very very solid power for the old RB26 on low mounts, gotta be happy with that.
Yep - and with this whole 2% difference thing the results are so close that there any range of minor variables could result in those changes, as said... a tiny boost leak, some other random thing that may have changed, even the way the tuner set up the boost control or conditions on the day. You can see that difference between a cold and hot run even, so it is a bit hard to jump to any major conclusions on - as Andy indicated.
Was it previously running a factory plenum?
It is easy to write off the results as insignificant... the increase in power and extended power band until later in rev range is more than likely due to increase plenum volume compared to anything else. You would see this with any larger plenum.
There is no mention of actual cylinder temps, if someone was serious they would have an O2 sensor in each runner, that would tell a story. Until then people can continue to scoff at the results so far which dont really say anything.
Can't really scoff at the dyno results - or otherwise, its so close.
If there is definitely a noticeable improvement in temperature across the 6 cylinders then it HAS to be a good thing. I'm a firm believer in making the engine happy first, and power gains being a result of that is a nice bonus - but the same power with a less stressed motor is brilliant.
2530s @ 24psi falling over @ 7200rpm on a 2.6ltr...
Boost control wasn't consistent from 5-6k...
Obvious something, albeit minor, was up beforehand.
(and again, not discounting the #6 reaffirmed etc, its all good and useful information).
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
