2009 Infiniti G37 Convertible
Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test. ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
