JoeyJoJo (I might have missed this)but where are you travelling now to get your fuel. I am holding out on doing an E85 tune because I want to be able to drive to get fuel and not take a jerry can :blink:
Is there much in the East side of Vic now? Someone was trying to tell me a servo in Hastings has it.
Cheers
-Jez
  • Replies 489
hoppers xing united.... but its sooo worth the trip...
i'm not gonna use anyone but united as they are looking like being the biggest supplier for the next couple of years.
as different places start to blend the ethanol with differing fuels 91 / 98 etc, i'm just gonna stick to tuning on the 91 ron blend that united offer as then i dont have to worry.
i'm not positive on dates, but united did say that kings way had it on their website for a while (it never did) and kingsway are due to have all their tanks replaced soon, so i'm guessing that's the next site. fingers crossed!
Hrmmmm, the missus live in werribee so hoppers aint too bad, but its a 100k drive for me just to get fuel. :blink:
Once there is one close to Dandy I will probably give it a go, probably need bigger injectors again:(
any car stands to make an increase, turbo cars moreso...... you have a highflow setup yes ash? if so expect a 280ish result :blink:
ye man highflow. going in to trent sometimes in Jan to get 670cc injectors installed and maybe cams if i can get my hands on some. mods apart from teh turbo is pretty similar to yours
highflow turbs
HKS intake and exhaust cam gears
denso 670CC injectors (to be installed in jan)
bosch fuel pump
Z32 AFM
Apexi PFC boost controller (to be installed in jan)
cams (still being looked into and hopefully installed in jan)
3" turbo back (might go decat)
will have need to have a chat with trent to see how it wll all go.
why did you get rid of vct?
have a good chat to trent about the cams, they are a lot of $$$ for what is in my opinion a negligible power gain.... unless you really destroy response
from the website...
United Ethanol 85 Locations
NSW
Service Station Address Phone
ROZELLE (SPEEDWAY) 127 Victoria Road 02 9555 7619
SA
SEATON 169 -171 Tapleys Hill Rd 08 8985 3486
VIC
HOPPERS CROSSING 160 Old Geelong Road 03 9748 3601
Speak to Trent about JT's R33, T67 very responsive and makes killer power on PULP, still runs the VCT IIRC.
I have been in both Joey's and JT's R33, although Joey's is tad more responsive they are both great examples on how to tune an RB25.
i didnt. previous owner got the gears installed
just drive to hoppers to get fuel, as Hamish says, worth the trip.
My R34 is permanently on E85, street duties, track duties... E85 all the way :)
I got Creatd to highflow my stock injectors, because the stockers have a nice 4 hole pattern, they're now 780cc i believe.
SOMETHING NO ONE HAS MENTIONED IS OILS AND COMPATIBILITY WITH E85
Consider using oils that are methanol safe. Ive been speaking to a few engine builders and machinist involved in E85 powered race cars (hint) and wear is UP TO 20% FASTER than experienced on "normal " fuels.
something i did look into with my oil choices. I found some stuff saying Royal Purple was suited to E85, but to be honest i couldn't find a whole lot about it. Asked about it over at bitog.com but didn't get much of a response.
Did pretty much confirm that you need to change oil a decent amount more frequently due to the E85 though.
When you talk about wear Trent... are you talking on engine components or UOA of the oil? Hopefully you're talking about the oil :ninja:
not much, but some advice from bitog
"High PAO, low ester, high TBN IMO. You want something with excellent hydrolytic stability and acid fighting properties. Mobil 1 Extended Performance, Amsoil, and I think some grades of Fuchs would probably be great choices for you."
i'm running 5w30 Amsoil at the moment, previously 5w30 RP - but yeah, happy to try others if you've got the inside scoop Trent :ninja:
EDIT: the other thing i found, which isn't much, is that for the owners manuals of the u.s. flex fuel cars, they don't recommend any specific oil, just that it needs to be changed more regularly (3,000 miles seems to be the norm)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
