ok this has been a long 5 month but its nearly dun its on its way to adelaide to boost worx for wirering and tuning mods r i thinck there a few more thing cant remeber so wat power could it be able to put out and how much can a stock box take
post-43842-1235659659_thumb.jpgpost-43842-1235659963_thumb.jpgpost-22250-1124707175.jpg
custom 3&half inch zaust
exedy 3puk clutch
tomie oil baffel
nismo group a turbos bathurst days
jjr oil catch can
cams
adjustible cam gears
gates racing timing belt kit
alc race bearing bigend and conrod
tomie pistons
jun rods
arp bolts
balanced r33 crank
sard 700cc injectors
sard fuel regulater
meatal head gasket
power fc de jetro & hand controller
greedy pro spec 2 boost controller
tomie fuel rail
clear timing cover
k&n pods
100mm thick front mount
splitfire coil packs
Edited by fab34
https://www.sau.com.au/forums/topic/258837-rb26dett-conversion-into-r34gtt/
is yours a RWD or 4WD GTT ?
any traction issues? lol
you running the standard GTR turbos or are they N1s.
gearbox should hold around 280-300rwkw considering its in good health.
got a rough ballpark figure of this conversion from start to finish?
this is something i wanna achieve sometime.
firstly you would be pretty dumb to put in a second hand engine...
for reliability you want to freshen up the engine, decent rebuild cost u 10k...
for a properly converted car you could get away with it for 25k thats probably wiv a freshen up, excluding buying a gtr engine
its expensive, believe me
We did a rb26 conversion nearly a year ago into a r34 gts4 so he could retain the 4wd, he supplied the engine and most other parts, in total his bill was approx 7k, wiring was prob the hardest part our wiring guru had his hands full but fired first turn key. really nice car to drive now its had most things in a hks cataloge thrown into it.
yea buy the time im finished with the wiring and tuning just over 20k so im looking 4 330rwkw 4 now till i get better gearbox
and yes there just standard turbos if thats wat they used in the godzillas in bathurst
I did all my own work my conversion was on a stagea, did not rebuild the 26 as it didnt need a rebuild have twin hks low mounts and dumps and front pipe pfc 100mm cooler 600cc injectors good street setup nice driver with twin plate clutch all up cost was 9.5k including buying the motor and box
what are the main wiring issues... im building one for my GTST
Thanks l'co. The engine we did this conversion on was from an r33 GTR. The main wiring issues were in combining the two looms. I try to do things pretty spot on and if it don't look like it should be there it ain't goin into 1 of our customers' cars. You've all seen those conversions with plugs that aren't connected hanging around and such. There are alot of inputs to an r34 ecu that just aren't there on an r33 gtr ecu. The only real issue was to swap things like the abs motor wiring and a couple of other things that escape my mind this instant and integrate them in the 33 loom. Admittedly, in the process the r34 loom was sacrificed for the better good. Anyway other than that, there's the obvious inclusion of the gtr injector resistor pack, a few alternative wiring modifications for the fuel pump relay (the gtr utilises a fuel pump control module) wire it up to power and hey presto! Basically if you have a decent amount of experience in reading wiring diagrams and fair soldering skills, you could probably do this job (given the time) as well. Just remember MINUS goes to red and PLUS goes to black, right? TIC. BTW All the wiring diagrams and all the info you need are/is on this forum.
yea mines rwd so im gona hav issues with grip a i still got stock rims and only 235s on her and bad camber
so itll kinda be like my mates rb20det s13 . doesnt even throw you back in the seat before its spinning . what a waste
solid center clutch or sprung ?
solid center mate and yes its goin to be a bit of a waste 4 now but every thing takes time and wheels and tyers and gear box r the next thing on the list
Edited by fab34
its not dumb if its a R34 GTR or Vspec motor.
good job mate, stock rims = lots of smoke & tyre frying lol
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
