hey all, droped the car off to boost works to get its 100k service, safc2 and greddy profec b spec 2 install today...
they just called me telling me my turbos were leaking, from what i gather its the exhaust side. he said 950 to pull it all out and change the gaskets for its such a tricky spot. i could pull them off my self if i needed to.
he said coz there wont be heaps of back pressure it will spool quicker and may hurt the turbos.
im not doubting his words at this stage, i didnt get him to go ahead simply coz i just cannot afford it! but how much damage will this be doing, can i do it my self? and where do i get gaskets from??
i was thinking maybe do the gaskets m self, and then trailer it in to get an exhaust done?
its on the 26 in the stagea btw!
Edited by chef_stagea
https://www.sau.com.au/forums/topic/259372-leaking-turbo/
was just speaking to cheff over facebook chat about this before he posted this up.
Will we just need to replace two of these http://justjap.com/store/product.php?produ...=318&page=1 ?
Also what gasket is on the exhaust side?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4455157
$950?
Just get the turbo rebuilt for that price, as you're probably still running the ceramics?
But for $950, they'd replace the seals as well I'm guessing.
Edit: yeah, they'd replace the seals and gaskets. Kit's for this start at $150 per turbo. Factor in that + labour for removing the turbo's, etc... the price sounds about right for what they're doing.
Edited by CRoNic...
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4455267
yeh thats it...
spoke to them its the rear turbo, turbo to manifold gasket, there are bolts missing (apparently a common problem) and yeah its just a massive labour job he said. also they told me i shouldnt go booting around as it spools up quicker coz theres no pressure on it? whats the go there? does it make sence and does he mean just dont rev the guts outa it?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4456780
yeh thats it...
if ya handy with a spanner do it yourself
that way u learn, n then if u get stuck call a mate u know with a 26 that knows about em
the best way to learn is do yourself and there is very very little you can do to stuff up a gasket change.
just take your time and remember you will have to drain coolant first and you wil get some oil leakage unless you block the lines up real quick after taking them off
on my mates sr it took us 4 hours to do a turbo and manifold off and back on, replacing all gaskets along the way.
if ya gonna have a crack at it and need to ask more questions pm me, i've done this stuff before.
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4456832
cheers dori, ive gota mate with a stag, and a mate with a 26 so im sure they will be willing to lend a hand ! i spoke to boost works and they said i wouldnt expect u to get us to to it coz of the pricw its just such a head case he said... how would you go about doing it? drop the coolant? exhaust n just start taking stuff off from there...
any thing eles i should look at, change or what ever while im that far in?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4457217
just drain the coolant first
then maybe a bit of oil if ya dont want to make a huge mess (if you use a clean container being new oil u should be able to put it back in, as long as you store it in a place where dirt and crap cant get
then take the front and dump pipe off
then take off the oil and water lines from both turbos
not 100% sure on room wise in a stag, but it will def be easier to take the manifold off with the turbos attached still
and then once off unbolt the turbos on the ground
that is basic but u get the idea, my biggest advice is DONT RUSH IT, if it takes two days, good better to be safe then sorry, and PLEASE PLEASE DOUBLE CHECK EVERYTHING WHEN YOU BOLT IT BACK
its not rocket science it just takes thinking and alot of 180 degree wrist bends to put that spanner on that nut that wont budge while reaching from the other side to pull the spanner lol
you generally dont have to replace every gasket that comes off
but in your case doing such a big job i would suggest every gasket that comes off should be replaced
so that is block to manifolds (yes theres two), manifold to turbos (two again), turbos to dumps, dumps to fronts
and with no stud on there if it is snapped drill it out and replace it with a nissan one
but at the same time, coz they arent that expensive i would replace all studs (save the hassle if they ever break again)(and they will)
have fun
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4458987
sounds like heaps of fun lol... ill speak to just jap i think about getting gaskets...
these studs your talking about? what are they?
and to make my day better the injector bottom o-rings r slightly leaking? is this a drama?? apart from loss of fuel economy, and a rougher idel?
what do i replace them with? just take of the injector wipe it off and change it?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4459451
speak to joeleo87, his work makes the o-rings for injectors, he can probably hook u up
-D
Edited by Dohmar
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4459519
Looking at the gasket you're replacing it's the one between the turbo and the manifold. If it leaks you can probably hear it, I had one done on my 33. As for not booting it i'm not sure that it will do harm to your turbo. Since exhaust gasses leaking before the turbo would mean less going through, less boost and less pressure on the turbo. If it was leaking at the dump side then it may cause it to spool faster but no more than you'd expect from a high flowing exhaust.
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4460265
very very true... did you get urs done at the place we spoke about? cheers
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4461346
Nah, i had mine done at nissan, cost around $700 there but i had all the manifolds machined, plus they are buy no means the cheapest place around.
I had my exhaust fitted there, they quoted me $100, but a bolt snapped, which happens unfortunatly, had to remove turbo to get it out, cost another $100 on top. $200 still a good price just for the install. They also did my timing belt and water pump at a very good price.
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4462236
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
