I am asking for troubleshooting advice for a R32 GTR. Yes I have searched but did not find an answer, just similiar issues without a resolution.
To the problem....
At the moment I am having issues with oil entering the coolant system. I first noticed it with a slight build up of brown greasy crap under the radiator cap. Since then I have flushed the coolant system, replaced the radiator, thermostat and am still getting build up of the brown greasy stuff in the radiator and coolant overflow bottle. It is definitely engine oil as it slowly being used, but did not seem to be affecting engine oil pressure.
I have run a TK Test for exhaust gases in the radiator (which there was none), completed a cold dry compression test with 5 cylinders coming up at 150 with cylinder 1 coming up with 132. I have also dropped the oil and it is not milky brown so it does not look like coolant is entering the sump. The spark plugs look fine with no obvious signs of contamination.
I am thinking along the lines of a blown headgasket (due to a low cylinder comp) between oil gallery and coolant galleries, however before jumping in and disassembling the engine I thought I would ask around as to what other things it could be or what other tests to run so that I can identify it as being a headgasket (or worse.. Cracked head).
The only other thing I can think of is potentially a problem with the water/oil seals on the engine warmer on the side of the block (where the oil filter mounts)....
Any opinions or help would be really appreciated as it has me stumped as to why I am not seeing any typical milky brown oil in the sump/head etc while oil is getting squeezed into the cooling system.
Thanks in advance.
The are two fairly obvious possibilities.
1. Brown greasy crap (dependent on how brown, greasy & indeed crap it is) can be a legacy of poor corrosion inhibitor maintenance from the past. Sometimes when these things are flushed they don't get all of the crap in the system but it can loosen up for later on.
2. Try the water/oil heater/cooler just behind the oil filter. This can & does fail.
Thanks for the info. Will check it out this weekend and see how the seals look on the oil warmer/cooler near the oil filter.
If it is not faulty, then I guess I have to rip the head off, and check out the gasket.....
Any recommendations on where to get the head serviced while its off? I am in the ACT so local or NSW workshops preferred.
What about replacement head gaskets? Tomei, HKS, Nismo or are they all the same?
Is it light brown sludge accumulating on the radiator cap? If it is, i'd tend to agree with djr81 on it being buildup from lack of coolant usage in the past. I had the same thing with my VL. Was a hassle to clean out.
If your coolant has turned to chocolate milk, then headgasket. And yes it can have oil go into coolant but not vice versa.
I had it happen once with oil going out the side and down block while coolant went into a cylinder in same area but no mixing of either substance.
I have the same problem and it has consistantly got worse over time.
from the above coments I will check the engine warmer first tho, I hadnt considered that.
the car is sweet in all respects apart from (over time) a heap of oil getting in the coolant.
I'm buying a house at the moment so the GTR is on hold until I get that sorted out so if in the mean time you identify the problem send me a PM.
cheers
i had that exact same problem with my 1st motor. Oil was always clean but slowly being used up. coolant was always contaminated with oil no matter how many times it was flushed.
turned out to be a stuffed oil cooler (the sandwich plate cooler between the block and the filter.) and a crack deep inside an oil gallery in the head. a new cooler and head and a small rebuild and i was good to go.
your choices in the order id look at are:
sandwich plate factory oil cooler.
Head gasket
Head
Block. (but i doubt it.)
good luck
Thanks for the info guys,
arep3, how did you find the small crack in the head? Pressure tested or x-ray'd? Did you source a second hand one or new? How much are they as a rough estimate?
Not having much luck trying to get at the sandwich plate. It looks to be a case of taking the inlet manifold off but it is an absolute b@stard to get at in the engine bay. It almost seems like a engine out job.....
Any tips?
if oil cooler/sandwitch plate is the problem i have 2 spares at home off a low km n1 block/motor
and yeah you'd probably have a better chance with the plenum off... if you do engine out you may end up spending $1000's with the good old "while its out i may aswell........"
bubbles came floating out of the gallery while in a pressure tank. it was too hard to repair. got a 2nd hand head for 1k. it had a snapped stud that had broke some alloy off which was rewelded back up and redrilled/tapped out.
the sandwich plate was swapped over with the motor in. the plenum was off and it took over 3 days...
there is a good chance of a crack in the head. it happens a bit and i've even sadly seen a brand new head that had a very, very small crack in a gallery somewhere inside. it was tough to diagnose as when cold the crack was not open and it would pass the pressure test. only after exhausting every option under the sun it was pressure tested at operating temp and sure enough there was a small leak. :banana:
yeah. give it a really strong flush with a propper radiator flush. but leave it in for about an hour and go for a easy drive.
flush it out heaps. and just use plain water. check it in a week or so.
very uncommon for head gasket. can be the oil cooler. unlikly its a porus turbo cartridge.
use a really light oil next change. it will exagerate th issue if there is one.
  • 1 month later...
Hey Guys,
Had the engine warmer checked out by my mechanic and pressure tested. No cracks.
Current mechanic is thinking it's a crack in the block and this problem was occurring before i got it rebuilt.
The mechanic who did the rebuild said he checked the block, head, etc... for cracks. Could anything else be causing this?
Taran
I'd say its a crack in the head. seen a few gtrs with this problem and its usually unrepairable. The last one i saw, car was a fresh import and when we pulled the head off somebody had already tryed to repair it.
Theres a good chance that all your rubber water hoses will need replacing as the oil makes them expand and go soft.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
