Hey all
Got and installed my new intake on the V35.
I also put a new K&N panel filter in. Its the same model number as a VS 3.8 litre commadore. A360.
It looks pretty good to me, i might use a longer piece of silicon pipe for the end nearest the box, but just to neaten it up a bit.
The sound is way better in the higher ranges and when the throttle is nice and wide open.
Down low, its great, no more noise than stock until you give it a hit.
Photos attached and a video with a digital camera.
The sound quality isnt great, but you'll get the idea i hope.
(I dont know how to add the video to the thread)
Edited by V35 Matt
https://www.sau.com.au/forums/topic/259921-new-intake-on-the-v35/
  • Replies 94
Posted Images
got the pipe off ebay. No idea what brand it is, but i like the stainless look rather than the plastic look of the z pipe.
Self install with a mechanic mate. But having seen it installed, anyone could do it without any worries at all.
Took 15 mins, as we removed some of the excess plastic from the box and the intake.
Now the muffler to install and it'll be complete as far as external mods go.
Hope to get better video over the weekend of the engine and the sound of the car going past.
wanna ask for some suggestion.. i heard somewhere that the oem 350z intake pipe is actually better, compared to stainless steel pipe, due to reason that stainless-steel pipe gets hotter easier and faster than plastic, so actually hot air are being suxked in..
Anyone can help to explain if this is right or wrong in anyway?
I do kinda agree if someone told me plastic gets hot the same way just like stainless steel... but it does also get colder faster than plastic rite?
this is the reason i still cant decide wat kind of intake i should buy and install on my v35.. ;)
The Truth from 350z is that the Intake is already a great design on 350z, They just need to use a Drop panel filter and it's already Perfect. But if you want the Noise you can go for the POD (ie JWT pop Charger). also most of the tuner in japan uses the SS tube like Matt did. So about the heatsoak i'm not too sure, if you want can just heatwrap it or so.
myself uses the CF Tube on mine with the K&N Drop in Filter.
to be honest if you want to get the Z tube. at least get the one from US version. It doesn't have that Water Collector/Resonator on the tube like the Australia version does.
Cheers
Is that what it is!?? I asked the question on the g35 forum a while ago and no one could tell me exactly what it was or how come theirs didn't have it. Oh well...still does the job I guess.
Yeah, that stupid appendix thing is a resonator. The US models didn't get it. I am pretty sure the Japanese cars did. It's for NVH.
Honestly, if you bought a 350Z you shouldn't be allergic to a bit of induction noise.
Yeah the stainless steel pipe does get a bit warm but I think it would be hard to notice a difference in power compared to say a CF one, would probably only show up on a dyno over a number of runs. I should probably feel how warm mine gets now since I put the Kinetix Plenum on, would help a bit I imagine as that isn't metal.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
