  • Replies 589
Thanks Terry - my thoughts are now clouded once again!
Further question too - as its in a bit of a remote area, and the drive is for a few hours; what's the Service Station availability there? Might need to organize jerry cans - car only really does 250kms per tank :wave:
The Members' SAU Cruise will refill if nec at the BP further up Bells Line Of Road incl. a pause there.
We'll investigate that for 98RON/Ultimate and get back to everybody.
'Tis good to bring the topic up.
You driving your car up this SAU members only cruise Terry?
No, I have to talk to Sensei Hans over at Dundas at 9am with regard to finalising the appearance, times and demo. of the Japanese Swordsmen on Anniversary Day. After that, I'll be making my way to Windsor Maccas and rock up in my 'Lude instead of my 'Line. Then I'll jump into mxfly's car.
I've got to see a Police Traffic Co-ordinator at 7am on Monday.
Just bought 50X Name Tags and now that Office Choice have run out, I've ordered 100X more.
Workshops and Car Shops are coming up to speed this week with regard to advertising this 10Th ANNIVERSARY of the R34 GT-R on their Homepages and Points of Sale.
All's good! Look forward to seeing you with other NSW Members on Sunday Raf!
Tez
Met a few 34's at the car wash and one at Parramatta Westfields today. All three said they are free on that date and will log on to SAU to check out all the details.
Snr Sgt Judie Platt ie. Traffic Co-ordinator (Blue Mtns) - after seeing her this morning...
will let Hwy Patrol Blue Mtns know by 24/4 that our Car Rally for 'Beyond Blue" and the Mag Photoshoot with Japanese Theme/Show will be coming up to Mt Wilson on 26/4/09 between 10am Homebush and 12 Noon Mt Wilson. She's emphasised NO SPEEDING and NO OBSTRUCTION OF Road At MT WILSON.
OK, off to Hawkebury/Windsor LAC now...
^^^^ Unfortunately you're not permitted to attend as that car will win all the prizes!
SEXY :blink:
Hahaha thanks for the kind words, i dont think so Eugene! The car has been stripped so much since the EPA inspection, engine bay looks stock now...
I'm just in it for the cruise with the R34s, should be good!!
I'm in for this one...
ZOMG?!!!!!!
Z-Tune Kit FTMFW!!!
That thing will decimate all (after you spend about 15 grand in it, or more, plus overnight parts from japan - sorry...had to throw in the lame fast and the furious quote)
Edited by Black Widow
ZOMG?!!!!!!
Z-Tune Kit FTMFW!!!
lol... thanks mate! z-tune styles all the way! another $15k could buy me a 2.8L stroker kit hahaha!!
#2 Police Station.
I saw Heather Smith at Windsor LAC and she says that our details are sufficient for the 26/4/09
I noticed also that at Homebush P6f, they've set up a ferris wheel.
Would it be best to have a Plan B starting point - or do you think that it'll be gone after Easter Tuesday 14/4/09?
DOOOO ITTT!!!!! You know you want to :blink:
#2 Police Station.
Are there any signs around? Maybe give them a call. They may be the organisers (or be able to point you in the right direction?)
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
