  • Replies 589
Thanks Terry - my thoughts are now clouded once again!
Further question too - as its in a bit of a remote area, and the drive is for a few hours; what's the Service Station availability there? Might need to organize jerry cans - car only really does 250kms per tank :wave:
The Members' SAU Cruise will refill if nec at the BP further up Bells Line Of Road incl. a pause there.
We'll investigate that for 98RON/Ultimate and get back to everybody.
'Tis good to bring the topic up.
You driving your car up this SAU members only cruise Terry?
No, I have to talk to Sensei Hans over at Dundas at 9am with regard to finalising the appearance, times and demo. of the Japanese Swordsmen on Anniversary Day. After that, I'll be making my way to Windsor Maccas and rock up in my 'Lude instead of my 'Line. Then I'll jump into mxfly's car.
I've got to see a Police Traffic Co-ordinator at 7am on Monday.
Just bought 50X Name Tags and now that Office Choice have run out, I've ordered 100X more.
Workshops and Car Shops are coming up to speed this week with regard to advertising this 10Th ANNIVERSARY of the R34 GT-R on their Homepages and Points of Sale.
All's good! Look forward to seeing you with other NSW Members on Sunday Raf!
Tez
Met a few 34's at the car wash and one at Parramatta Westfields today. All three said they are free on that date and will log on to SAU to check out all the details.
Snr Sgt Judie Platt ie. Traffic Co-ordinator (Blue Mtns) - after seeing her this morning...
will let Hwy Patrol Blue Mtns know by 24/4 that our Car Rally for 'Beyond Blue" and the Mag Photoshoot with Japanese Theme/Show will be coming up to Mt Wilson on 26/4/09 between 10am Homebush and 12 Noon Mt Wilson. She's emphasised NO SPEEDING and NO OBSTRUCTION OF Road At MT WILSON.
OK, off to Hawkebury/Windsor LAC now...
^^^^ Unfortunately you're not permitted to attend as that car will win all the prizes!
SEXY :blink:
Hahaha thanks for the kind words, i dont think so Eugene! The car has been stripped so much since the EPA inspection, engine bay looks stock now...
I'm just in it for the cruise with the R34s, should be good!!
I'm in for this one...
ZOMG?!!!!!!
Z-Tune Kit FTMFW!!!
That thing will decimate all (after you spend about 15 grand in it, or more, plus overnight parts from japan - sorry...had to throw in the lame fast and the furious quote)
Edited by Black Widow
ZOMG?!!!!!!
Z-Tune Kit FTMFW!!!
lol... thanks mate! z-tune styles all the way! another $15k could buy me a 2.8L stroker kit hahaha!!
#2 Police Station.
I saw Heather Smith at Windsor LAC and she says that our details are sufficient for the 26/4/09
I noticed also that at Homebush P6f, they've set up a ferris wheel.
Would it be best to have a Plan B starting point - or do you think that it'll be gone after Easter Tuesday 14/4/09?
DOOOO ITTT!!!!! You know you want to :blink:
#2 Police Station.
Are there any signs around? Maybe give them a call. They may be the organisers (or be able to point you in the right direction?)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
