  • Replies 95
Posted Images
i think im gonna make this... :thanks:
but i do need to get my wheel alignment sorted, does anyone know of anywhere in the SE suburbs that hook me up with a killer alignment?
it used to be great, but since i replaced one of the tie rod ends ive had no luck being able to get back my nice set up. now all i have is under steer and PLENTY of it!!! :thumbsup:
conserned about noise levels .... and the chance of rain as i will be running economic crisis spec tyres.
How do you think me car will go with noise restrictions there????
Im really sitting on the fence here
when is the latest you can pull out and still get your money back
With the WRX Club i have been pinged because of noise. If you take it easy for the first two sessions and change up at 4,000rpm ( :O ) and keep the gate closed you can get some good sighthing laps under your belt. Last time i was there i got two sessions where i gave it curry in the afternoon. Total of 5 laps in anger :D But still good fun...wich i was able to make it. :banana:
Because some parts suppliers are rats...
Had some issues with my fuel system and have been dicked around. We want to make sure the car is right before it hits the track to minimise teething issues, so instead of rushing it we decided to go for Sandown later in the month. Not happy about it though... not happy at all.
Man, i think my car with the Bislteins would have done a 1:50 if i didnt use 4th gear at turn 1 and i got the line onto the straight properly then there might be a bit of time in it. Its possible?!?!?!! I did a 1:52 flat and because the EPA guy hung around all day i only got a few laps to try
So
On the first lap the tyres were still not quite warm, was rough and ready with a few errors and it was a 1:52.00 flat. So close to a 51 :O Looking at the corner speeds and data for the second lap i was quicker through turn 1 and turn 2 & 3. I lost time on Southern Loop. I also messed up MG but got onto the straight way faster then i had on any other lap on the day. So the second lap in the vid had some good bits but i ham fisted MG but the lap was still a 1:53.1 or 1:53.4 so ?!?!?! Its definitely doable.
LOL, i hate that somebody else in the club, (Ryan or Matt) will be the first into the 49s before me :) LOL, i am no longer willing to bin it trying...paint costs way too much money.
But seriously if i am delusional in thinking there is a 1:50 in the car in the vid then i want to be set straight...i dont want false expectations for myself and the car. :wub:
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
