  • Replies 94
The order will be done hopefully tomorrow. One or two stragglers to pay. If you want in better contact maximus007 pronto.
Buying an ISO Copper yourself will be AU$510.... up to you if you decide to wait for Kev'07's $$$....
Edited by Aust350z
Guys - group buy is complete and packages have been posted :P.
Thanks for organising it all - i appreciate that...
Whats the expected time frame for these things to arrive?
Where can i pickup my one from, or who do i speak to in Sydney *shrug*? :D
Estimated at just over a week - I'd guess Monday week.
Pickup details in email. :P
Is everyone going to install them themselves? Can it be done by a mechanically challenged IT guy :D
I'm mechanically challenged as well. If anyone wants to make an afternoon of putting these on I'd be interested.
it wasn't that hard as i done one before on 350z, but only done the Basic one haven't done the ISO one lol. Just watch Youtube people. all Is there lol.
on the video from Motordyne, i don't get the bit that put the ISO gasket with something green. Whats that anyway? any idea?
Edited by pw350gt
for all those who missed out on the group buy like me :) , i just purchased the motordyne 5/16 iso off ebay from riverside infiniti for $US220.24 and $US38 for shipping to sydney. This worked out to be $AU376 with the dollar at 68c.
Good work.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
