So the goverment stimulus packages have started rolling out, for those of us who get it who's doing what to your car with it? Or are you using it for other stuff in life (there's something else then car's?!! :D )
Ive decided to use it fix everything that is wrong with my stagea. Amongst all the fixes there is one mod i snuck in :)
The list is as follows:
New ISC 52mm rad
New thermostat
Coolant flush and chnage
New tie rod ends
New rack ends
New rack bushes
New sway bar bushes front and rear
Adjustable castor rods
All up comes to just over $1000 so i have a bit to come up with but not the full amount.
I also have sitting here for it which i havnt fitted:
New fuel pump
New engine fan (mines cracked)
HICAS breaker bar (this will be the 3rd time ive tried to fit it as i cant find a tie rod splitter to fit :D )
So this will pretty much everything that is wrong with the car atm. So then i can put the price up :D jokes.
So what are other people doing? Confess!!
WTF is a HICAS "breaker" bar ? do you mean a hicas lock bar ? and if so why do you need a tie rod splitter . mine took half an hour to jack up and swap hicas rack with a new one . only slight issue was getting a spanner on passenger end of the rack because the exhaust was kinda in the way
  • Replies 79
Yeah sorry hicas lock bar.
I did a 34 once without splitting the tie rods where the rack connects to the hubs. Only one side came out the other didnt have enough movement. So i didnt bother with this one. Might try it when i get it in the air next.
Good job im ordering a rad, mine just split the bottom tank today!! HAPPY!!
Big Kev the second is paying for my Power-FC re-tune for my RS4s as at the SAU-Vic dyno day my peak power was only 110awkw at 4000rpm and the power went down from there?
my old rs4s went from 125rwkw to 200.9rwkw with a PFC install/tune
OK so i got a little excited and started ordering the parts before the money got here as i had to rush it a little. I had planned on getting a new rad which was handy as mine split on me last week. So the car hasnt moved since last monday.
So i have so far:
Got the rad out and flushed the coolant out and changed thermostat also changed the engine fan. (waiting for new rad to arrive)
Fitted the rear Hicas cancellor and rear camber arms.
Fitted the a autometer boost guage and mearcat pod i had from the old RS4
Started fitting the fuel pump
Then the fun began, today my bushes turned up that i orderded. Front and rear sway bar mounts bushes, rear link bushes and steering rack bushes. I never measuered my sway bars i just went the stock size... well i should of.
Stock size rear is 18mm mine is 24mm
Stock size front is 22mm mine is 28mm
So it appears i have aftermarket sway bars in there, so im happy for that and sad that i spent $100 on the wrong bushes. So i have to order some more now.
So i thaught OK i'll do the link bushes while im here, and what happens both links one end shear's off... So ive just ordered some new links coming ex east be here in a week...
At least i have a sense of pride as im definatley doing my part for the economy now!
OK back out to the garage to see what else i can break i mean repair.
So i have so far:
maybe 260RS is GTR sized bars?
Well I picked up an S13 for $500 on saturday so i guess i will put the money straight into that. It may not get me an SR20DET from DE conversion but it will
get me this kit!
What it looked like this morning:
And now:
Drift or road car im not sure yet, either way when finished it will have cost under 5k!
So the Stag gets nothing for now :P
I rang a suspension place here in WA. And they told me the sizes, and said there stock 33 GTR sizes? I dunno? Maybe autech put diff sway bars in?
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
