I drive an R32 GTS-T with the stock ECU and an SAFC2.
Recently, I got new suspension installed and the workshop had to disconnect my battery due to disconnecting the stereo (mounted on the back of the rear seats).
I'm wondering if the previous dyno tune I had has now been thrown out the window. The reason I ask is my fuel economy has now gone to hell, and all the benefits of the tune are gone.
If i get a remap done to the stock ECU - will pulling the battery cause the same thing to happen? Does this also occur with aftermarket ECU's like the PowerFC etc.
https://www.sau.com.au/forums/topic/261158-lost-tune-after-pulling-battery/
Yeah, I don't think the SAFC2 has lost it's settings. What I think has happened is that when the battery has been disconnected and then reconnected, the ECU has started learning again, but because it's also getting information from the ECU it isn't learning correctly?
Can anyone shed some light on this?
Sorry if I'm not being clear :<
you can take a tuned ecu/piggyback and sit it on a shelf for years. it will still retain all its settings.
if they shorted it out, then maybe the unit is now faulty?
Edited by Munkyb0y
They use an EPROM.
In short, the EPROM is a memory part which will not forget its program or data when power is removed.
Very similar to your ECU. It still retains the normal engine management functions after disconnection of the power source.
The safc2 will not lose its settings when the batt is disconnected.
However when the ecu is reset by removing the battery it does "learn" a different setting with the changed air flow voltage it gets from the safc.
I've experimented with this in my car so let me explain a litle more....
When u install the safc once u've raised boost etc. and the ecu goes into rich &retard mode and u tune the safc, the ecu learns this tune in its "protection" mode or what ever u want to call it.
When u now reset the ecu with this same setting on the safc ,the ecu no longer goes into "protection" mode because u have leaned out or decreased the voltage the ecu sees, so what now happens is the ecu now tends to advance the timing a little too much and afrs tend to go a little more lean as well so u start to got knock.
So what i normally do is get a basic tune to get rid of r&r as much as possible, reset the ecu and then fine tune the safc again to get the best results.
Now this refers to the rb25det, and as far as i know the rb20det does not have r&r protection... so i was merely using this as an example to show that it is possible for the ecu to learn a different setting with the changed airflow voltage from the safc when it is reset.
Is this the first time since the safc was tuned that u have taken off the batt pole?
U could probably try resetting it again. Or put a wideband on it and see whats going on......
Rb ecus are weird :banana:
read through the SAFC2 manual and figure out how to switch between file 1 and file 2. file 1 should be your tune and file 2 should be a cleared map with no adjustments or vise versa, it doesnt matter which way it is - just dont delete it accidently.
switch to the file with no settings then reset the ECU again and go for a drive.
switch back to file 2 and it should all be back to normal.
Smell: You hit the nail on the head, and yes - it is the first time the battery has been disconnected since getting the tune.
SECURITY: Thanks for the tip mate, I'll give it a go. Any idea if the SAFC2 manual is online?
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
