Good Morning all.
Another glorious day and im stuck at work.... life is great.
Don't work to earn money. Work to evolve your thinking and the money will come naturally!
Morning Mangs,
On the train, gold coast sucks :(
This train only goes to the city and the airport, and spends the entire time exactly 3 minutes BEHIND the caboolture train.
So I'll have to get off somewhere and wait 27 minutes for the next one :( :( :(.
Then I have to go to work.
FML
Update: On the right train now :). Decided to turn my half hour break into lunch. The line up at KFC was epic, but it was worth it because as I got to the front of the line they dumped a load of fresh nuggets, so I spontaneously changed my order (because nothing beats fresh nuggets). However I then due to the length of the line I only had 5 minutes to smash my 18 nuggets. Shit got epic.
Also, saw a dude dressed up like the guy from pokemon. No shit, motherf**ker looked exactly like this:
Ha had a stuffed toy pokemon in his backpack and everything
I saw lots of dressed up people in the city/valley i have a feeling nerdfest 2011 is on, also known as supernova or somthing. I was made to go once every one was a dickehead and smelled bad
Yeeeeep, supernova is indeed on this weekend. Lucky he didn't try and trap you with his pokeballs McFly.
Ahh, that would probably be it.
LOL
Aaaannnnndddd.... Now I'm at work :(
Home again, much shorter shift tonight thank god!
Silly drunk people who can't hold their liquor made life interesting tonight as we couldn't hail a cab for love or money. All the drivers were off the road tonight for some reason...
*Wanders off to find the result of ICC World Cup final*
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
