Holy ghost Batman! You're still around! How the hell are you Josh?
Not around that much - From time to time I go German dinners that the guys in this thread do.
Don't own skylines, not a paying member not really any point being on here ;)
Busy with work though, back working Bulimba (Was in New Farm for 2 or so years). Still playing with (a) car. Need a tow rig though, stupidest friggin car to drive on the street.
Used to be high-compression, ridiculous timing and av-gas/race fuel only. Here I was thinking de-tuning; running lower compression and 98ron would make it "easier". I laugh at my own stupidity
A stick with a sign on it would be more useful than our receptionist. Less temperamental too. domokun.gif
We could use a couple of those sticks with signs in our service department. Group buy on sticks with signs?
German dinners, bring it on! I have been missing out it seems.
Next time you are anywhere near Emporium give me a bell and come around for a drink or 20 at Ristorante Tartufo (my second home)
Sign my stick?
Winning
Keen for stick signage
Winning
Can I get your sister to sign my stick?
Epic Winning
In for Col's Sister signage.
Epic Winning
Yes, With a sharpie.
Winning
Needs moar crossing of swords?
Um.... not so winning... :blink:
sound good...what the hell is it?
dammmmm it
stupid bike shop gave me the wrong oil filter...
how do you get a honda filter when you ask for a Yamaha one... f**k...
now i cant go anywhere in the morning, cant put the old one back on either as its got a pin hole in it... :rant:
have to wait til monday night to fix it up now... cant even put oil in it now...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
