Holy ghost Batman! You're still around! How the hell are you Josh?
Not around that much - From time to time I go German dinners that the guys in this thread do.
Don't own skylines, not a paying member not really any point being on here ;)
Busy with work though, back working Bulimba (Was in New Farm for 2 or so years). Still playing with (a) car. Need a tow rig though, stupidest friggin car to drive on the street.
Used to be high-compression, ridiculous timing and av-gas/race fuel only. Here I was thinking de-tuning; running lower compression and 98ron would make it "easier". I laugh at my own stupidity
A stick with a sign on it would be more useful than our receptionist. Less temperamental too. domokun.gif
We could use a couple of those sticks with signs in our service department. Group buy on sticks with signs?
German dinners, bring it on! I have been missing out it seems.
Next time you are anywhere near Emporium give me a bell and come around for a drink or 20 at Ristorante Tartufo (my second home)
Sign my stick?
Winning
Keen for stick signage
Winning
Can I get your sister to sign my stick?
Epic Winning
In for Col's Sister signage.
Epic Winning
Yes, With a sharpie.
Winning
Needs moar crossing of swords?
Um.... not so winning... :blink:
sound good...what the hell is it?
dammmmm it
stupid bike shop gave me the wrong oil filter...
how do you get a honda filter when you ask for a Yamaha one... f**k...
now i cant go anywhere in the morning, cant put the old one back on either as its got a pin hole in it... :rant:
have to wait til monday night to fix it up now... cant even put oil in it now...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
