I'm sure those guys is just as cool as we are.
yeah i was just joking...
and surprise bumsecks is definitely something that will encourage him.
what, no fair... last time he just called rape...
Totes stopping into C-dine on my way home to see skidpan.
all you will find is super clean patch's of concrete... they fixed it up this morning with a leveling machine...
do you like live in this car park or somthing? You seem to have a lot of information on the goings on there! lol
maybe.... :(
the bins are newer than the ones at chermside and their far more insulated at night...
nah, i live 5 mins from here, its my local woolies, coffee, capers and sushi...
Alarm is set mangs. Noel, colon, I will sms you when I leave here. If I haven't sms'd you by 6, I'm not coming :P.
Hey what time is the happy laps at lakeside tomorrow?
Not tomorrow dude, may 22nd.
Sarp mangs. Whale watching tour was epic. Noel/Pete noise in the car went away. Thinking it might be something with the exhaust after I hit that hump in the road. It was coming and going when I was on the highway at like 100km/hr so maybe it's a vibration/resonant frequency deal with the exhaust.
Mangs
Know anyone who's worked at Ford as a mechanic or spare parts person? Need to work out what to do about my fusebox and the bonnet release lever and how it's snapped and all.
Housemates pants friends cats are staying with us at the moment, that makes 3 cats in the house. I think I'm going insane. One was bad enough!
Come on 5pm tomorrow. Can tell next week is going to be good, everyone will have taken the 3 days off, go to work and do my certifications!
EDIT: Can't believe I missed this:
I can has 26?
Its usually the bonnet release lever that snaps off the fuse box. Is the fuse box where the bonnet release mounts to it damaged at all? Its a common problem with BA/BF falcons for them to snap. I have changed a few of the bonnet releases over. You need to change the whole cable over with it. Absolute prick of a job to do.
So you all wanta use the new shopping centre at carseldine to meet hey...?
Well I went down last night in the family mobile to go to Woolworths to so the weekly shoping and the Police had the car park blocked off...
Apparently the business owners DONT want car meets in their carpark, there were about 150 cars being polity told to "bugger off"...
Defect noticed given out left right and center... I asked at the checkout in Woolies in a friendly conversation starting manner as I had the the assistant manner as my checkout chick... She said that last Thursday night there were over 100 cars and they left skids in the underground carpark... The center managers had complaints from customers and from store owners, so they see a bunch of cars pull up and stand around talking and they automatically call the police now...
Good luck using the location... I think Nandos and Pizza Capers might be over ruled by Woolies some how...
Hmmmm thats weird because we were asked last week to organise a cruise by the owner of nando's for this Anzac day .... with approval from centre management (the owner of nandos drives a RX7 series 8) :
Ack, i road raged at someone who was doing 50 in an 80 zone on the way back from viccy point just now. Not a fan of them doing 50 in an 80 zone, just feel bad that I snapped and yelled stuff out as i went past.
Bad Image too :domokun:
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
