Lies and slander. The newsagent shuts at 8 and I have only failed to aquire a red bull from them once.
But on that note, I might be a bit late tonight :P. Have to recover my XF on the way...
Lies! I mkae them stay open so you get your red bull. :whistling:
White R33 S1 Gtst (any stolen today?) rear bumper was well gone so couldn't see a number plate...
Had an sau sticker on the side window (little qtr glass bit)...
was done today, tow trucks were working on scratching their heads on how to get it out...
I know one like that. had it about 6 months ago doing the locks on it. he's on here. (defari)
Anybody have a heat gun I can use over the weekend?
Want to get rid of the rest of my sound deadening and carpets
from all accounts dry ice is the go. apparently so much easier then heat gun and it leaves the floor pan all clean and not sticky.
Dry ice is good for large areas, but heat gun is defs the go for everywhere else.
In fact on Martin's alfa we found the heat gun to be more effective than dry ice.
Heat guns are like $30 at bunnings.
Morning Mangs,
TFIF.
yeah it definitely depends on the 'type' of sound deadening.
Dry ice in the 31 ute cracked the stuff off no trouble, but in the alfa the heat gun worked better.
Given that 32 sound deadening is probably similar to 31 stuff, I'd suggest giving dry ice a crack.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
