You guys should count yourselves lucky if I bother to grace you with my presence at all :P
we really do, Its important we have sonething to laugh at.
got a farken $300 fine and 3 demerit points for rolling through a stop sign just near RBH. The farkers were hiding up the road with a video camera filming it....
thats normal. I used to see them there most days. bit annoying when they follow you around trying to ping you. happened in CHOY GTR a couple of years back.
glad they got you off the road...man that could have been dangerous??
:whistling:
they are usullay sitting on herston rd or campbell st. both are blind to the driver but clean shots for cops. i got used to it and knew here to look. still sucks though.
I must learn to stop at them then... don't particularly fancy any attention, especially for something that minor!
subaru sold. amazing how people try to screw you down. was offered $275 for it...
final amount was $1550. so that pays for the HR31. I dare say it will stay a local car as the company that bought it had NO idea what they bought.
the salesperson had half an idea after I took him for a strap in it and got in on the second turbo..
now have moneyz for HR31 tidyup and rego. whats 6cyl rego worth btw for 6 months?
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
