I'm the same... It's a work tool, it saves me hours every week...
Laptop battery never lasts a day and it takes too long to boot up all the time...
I still need my laptop but only need to use it once a day as the iPad can do the rest...
I can't believe I've gone this long without it
iPad as a work tool ftw! It just makes doing things so much easier incl constructing mind maps whilst with clients at a cafe, or sending through candidate details as you wait for someone. Work is easier on an iPad - fo shizzle.
Anyway, sup mangs?
Mangs,
It's finally over after a massive week/weekend trying to get everything sorted. Worked from 8am till Midnight on Sunday prepping for the certifiers inspection yesterday. The Client was really impressed with the building and ended up giving us PC yesterday, got absolutely hammered last night and had the day off today lol. 18 months of hard work but it's all come good :) Now I'll be able to spend some time fixing the car and relaxing a bit lol
German club some time this week?
Mangs,
Who the f**k are you :action-smiley-069:
Good news Col!
Keen for german club
Yeah maybe next week. Pretty flat out with uni/drinking this week lol.
Good to hear mate :) when's the new job start?
Also, scrackin mangs?
New job has started already at Indro. The office tower at Southpoint turned to shit so no new job for me. Hanging around at Portside doing purchaser inspections for a few months before going to Europe. Will be an interesting few months. The rest of the team is being broken up now and reallocated to other projects.
german club sounds good soon. wanna bring the wife with me....for some more german sausage :rolleyes: and beer of coarse
Nice.
Browsing yahoo auctions japan. R32gtr vspec with 75000km in TH1 blue pearl and a kcpg10 gtr, both with starting bids of 10K. No doubt they'd go for a fair bit more, but a guy can dream!
I see how this yahoo auctions japan thing could drain ones bank account. so many bargins, gotta buy them all to make sure you save the most money possible
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
