  • Replies 105
hey everyone
thanks for all the emails and very amusing posts.
The shortlist to pick up Paul is:
R34 Z-Tune
Dom from Autostyle blue R34
and a Millenium Jade M-Spec NUR with 19-inch Volks on it
Vin will be going in a decked out Chrysler 300C and/or IS250
hey everyone
R34 Z-Tune
Why?
Universals taste in cars =
Edited by Black Widow
post-9339-1237421205_thumb.jpgwhat about this
hell yeah. I always knew you had taste greg. always been a snapper dresser!
c'mon andrew. as if vin wants to be seen in a 300C. they are just a poor mans caddy in the US. and still a cheapo car here. go the valiant. it's aussie and has some style! and will blow a 300C into the weeds.
hey everyone
R34 Z-Tune
Seriously though, same car??
edit: no it's not, this is a VspecII.... sorry
still think its homo that they can't have outside input.
They've given you the task of helping find these cars. You should have input as to what they use.
We know whats good...
No one else opinions matter :)
actually, enthusiasts aren't their target demographic, if it was they wouldnt get enough viewers. there taret demographic is " as many people as possible to buy tickets"
Cars had to be approved by Universal Australia and US. Publicist had to see it etc etc etc
you work i this industry you get used to it and just deal with it
hey everyone
R34 Z-Tune
not to sound like a party pooper here...
but seriously i dont see the point of all your hype.....
you asked everyone on their opinions....and for everyone to post you pictures of cars to suit...
but at the end of the day... none of the cars you mentioned that were picked ad nothing to do with ANYTHING, anyone has posted..?
so at the end of the day, everyone just wasted their time ?
anyhow
hope the movie is good
coz if not that would be 3 strikes in a row.....
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
