Just thought I'd share with you some very handy info I was given tonight (by a Nissan tech).
Its easy to check the ecu fault codes - something I didn't realise.
I believe the below would also be in the manual...
(btw MIL = Malfunction Indicator Lamp - otherwise known as CEL / Check Engine Light - its orange and on the right hand side of the dash in the M35).
ACCESSING:
NOTE: To access trouble codes, accelerator pedal position (APP) sensor must be functioning correctly.
  • Ensure accelerator pedal is fully released
  • Switch ignition ON. DO NOT start engine
  • Wait 3 seconds
  • Within 5 seconds, repeat the following 5 times:
  • > Fully depress accelerator pedal.
  • > Fully release accelerator pedal.
  • Wait 7 seconds.
  • Fully depress accelerator pedal and hold.
  • After approximately 10 seconds MIL will start flashing.
  • Fully release accelerator pedal.
  • Trouble codes are now displayed by MIL.
  • Count MIL flashes.
  • Compare to trouble code table.
  • Each trouble code consists of four groups of one or more flashes.
  • Ten flashes in a group indicate '0'.
  • The first group of flashes indicate the 'thousands' of the trouble code.
  • The second group of flashes indicate the 'hundreds' of the trouble code.
  • The third group of flashes indicate the 'tens' of the trouble code.
  • The fourth group of flashes indicate the 'units' of the trouble code.
  • A short pause separates each trouble code group.
  • A long pause separates each trouble code.
  • Switch ignition OFF.
ERASING:
  • Ensure accelerator pedal is fully released.
  • Ensure ignition switched OFF for at least 10 seconds.
  • Switch ignition ON - DO NOT start engine.
  • Wait 3 seconds.
  • Wait 7 seconds.
  • Fully depress accelerator pedal for more than 10 seconds.
  • Trouble code 0000 should be displayed.
Mine showed the code 0000 (10 flashes x 4 times) so didn't solve the problem I was looking for but at least I know all the sensors are working etc. :D
Edited by pixel8r
https://www.sau.com.au/forums/topic/261557-ecu-fault-codes-the-easy-way/
Just realised the above is all in the manual. For those who dont know, you can find all of this an much more related info in the infinit G35 service manual which you can find online - do a google search. The infiniti G35 is what we know as the skyline V35. :pirate:
There's also more diagnostics for checking fault codes on other systems in the car too.
I managed to get it to work eventually for me and got 0000 also.
No closed to knowing why idle is 150rpm too high but I will start looking for leaks around the throttle body and a few other areas.
Cheers
Andy
it was weird i tried that so many times and it didnt work on mine
Did you get it to the point where the MIL start flashing?
Read below for the plain english version...(by me)...
You may need to use a stopwatch or something to count the seconds.
Turn ignition to ON (dont start engine).
Wait 3 seconds
Then over the next 5 seconds, push the accelerator all the way to the floor and then release it fully - do this 5 times quickly within these 5 seconds.
Then wait a further 7 seconds.
Now push the accelerator all the way to the floor again and hold it for 10 seconds until the MIL starts flashing.
When you see it start to flash after 10 seconds, release the accelerator straight away
the light should then keep blinking - giving you the fault codes. it will flash up 4 codes, pausing between each. it will blink slowly for the first group, then fast for the next 3 groups. 10 flashes in a group = '0'.
ie. code 0123 would be 10 flashes, pause, 1 flash, pause, 2 flashes, pause, 3 flashes, long pause, repeat...
turn the ignition to OFF when you're done - this will exit the diagnostic mode.
next time you start the car it will be back in the normal driving mode.
I just gave it a go myself, first time I didn't get it to work.
Then I closed the driver's door incase that had anything to do with it and when I counted the seconds I used the old school method (1001, 1002, 1003 etc.)
It worked and I also got a return code of 0000 :D
This is a good thing I assume!
  • 1 year later...
Hi all,
Just reading this info, but wondering where to find the fault code info? The infinity G35 manuals I can find are all for the 3.5l v6 non turbo. Am I missing something?
I'm after code info for a m35. Sorry for the old post resurrection!
  • 1 month later...
ACCESSING:
  • Wait 3 seconds
  • Wait 7 seconds.
ERASING:
  • Wait 3 seconds.
  • Wait 7 seconds.
Mine showed the code 0000 (10 flashes x 4 times) so didn't solve the problem I was looking for but at least I know all the sensors are working etc. :verymad:
Guy's I'm having problems with my Airbag light keeps flashing
Ive got a 2001 Stagea ARX4 and theres nothing wrong with the airbags but the light keeps flashing.
Is there a way for me too reset the light cause its possing a problem with me.
Will the ECU Fault Test reset the Airbag light or is there another way.
Im in need of Stagea Help
Dont Worry allready fixed the problem LOL :)
If it's the same problem I had it may return in a few weeks. Mine seems to set off now and again under boost going uphill (atleast that was when it went off last time).
I have a code but as of yet it has been of no use, I have taken pictures of the error screen(s) that came up and am waiting for them to be translated in the hope it sheds more light on the issue.
It has been suggested it could be the seat belt pretensioner but as of yet I have not investigated this as I had disconnected and reconnected the cables under the drivers seat and reset the ecu.
Let me know if you have further issues, we may need to discover the problem together.
I still have the airbag light up but it matches the Mil light that's constantly on.
The reset works for a while which is why I think the tensioner is the issue as they are known to fail, its a bad connection somewhere.
Bis-e-Bee, If you could send me the error screen and codes I will see if the nice Japanese lady at work will translate it, she did a wonderful job on the ecu pinouts.
have you tried to get the Error code on the Informeter? There is in the Setup menu a DTC option which brings up the code.
  • 2 months later...
still havent gotten it to work... will try again now.
im wondering if my aftermarket alarm has anything to do with it..as the alarm has a 30 second timer before it disables ignition and requires disarming for the engine to start.
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
