I just gave my car a little right foot on the freeway in 4th gear and noticed i was hitting 10psi at 4000rpm instead of after 5000rpm.
So I'm guessing my lag issue is all in the tune. Can it really make that big of a difference
Lag will be less in higher gears. This is because there is more load on the engine in higher gears. It wont be the same in every gear.
What gear does it take till 5000rpm to hit boost?
In 1st and 2nd i'm not getting 10psi till after 5000rpm just noticed this morning in 4th and 5th im getting 10psi around 4000rpm.
So theres slightly over 1000rpm difference, don't forget Stao said this turbo should be getting 20psi by 4300 so i would epect 10psi by say 3200 - 3500
With the stock comp housing, you ended up with half mm each side of the intake pipe. lol. But do run it with 3inch intake pipe, stock pipe will restrict power flow.
Because the stock turbo intake is being used it will need to start at 2.5" or 60mm (turbo end) and then increase to 3" as quickly as possible. Something like this is as good as I can find:
http://cgi.ebay.com.au/ALLOY-INTAKE-PIPE-4...=item25597be9f9
Is there any advantage to increasing the pipe size to 3" if its restriced to 2.5" at the turbo intake anyway?
Edited by Harey
Im not commenting on the overall responsiveness of the turbo, but I could imagine somewhere near 1000rpm difference in lag between 1st and 4th gears.
ok so then its still has extreme lag.
Any one got a dyno sheet of the ATR43G3 showing boost and rpm?
This has power and speed.
http://www.digi-hardware.com/images/dynosh...rwkwcompare.JPG
Post up yours and we can compare.
No Dyno yet in the process of raod tuning the car, maybe i haven't been aggressive enough on the timing
Also going to replace my oil drain as i suspect maybe there is a kink in it
Edited by Crans
if you dont understand that boost repsonse is different in 1st and 2nd to 4th and you don't know how fast turbos spool up exponentially, tuning your car yourself is going to end up in tears
Yes i understand boost response is different between the gears and exponential growth in spool. I just didn't realise there would be over 1000rpm difference between 2nd and 4th not to mention extreme lag is still a problem
I am only doing basic mapping on the street i.e. getting fueling as close to perfect as i can and getting some extra timing in to help response, the rest will be done on a dyno.
I have tuned other cars before with ok results and being very safe and reliable still.
Based on this dyno print out of boost vs RPM http://www.digi-hardware.com/images/dynosh...3boost15psi.jpg i should be making 6psi by 3000rpm and 10psi by around 3300rpm
Edited by Crans
most turbo cars with decent sized turbos will have 1500-2000rpm spool difference between 1st and 4th gear
OK cool i didn't realise the difference was that much.
Oh wow its not tuned yet!! I agree with other people here, spend the cash on a professional tune. A tune will greatly affect the response of a turbo. It will be worth its weight in gold.
I think its unfair to give Hypergear bad feedback without a proper tune.
Edited by Harey
Not giving bad feed back at all, when boost does come on it feels very strong. I am going to tune the car my self and get it checked and adjusted on a dyno.
Like a lot of people i would prefer to do most of the work my self and learn on the way.
Other thing needs to be mentioned is that ATR28G4 unit is running a .82 turbine housing. The one with full boost at 3500RPM is running on .63 turbine housing.
.82 turbine bousing based boost and power curve should be:
http://www.digi-hardware.com/images/dynosh.../atr43360hp.jpg
All the new ones now has the wastegate controller lever, which allows you to run 20psi+ in a steady curve.
Also get rid of your stock rubber pipe. You can't get a decent tune out of that, it will suck bend and suck it self partially shut in random shapes. impossible to get get a constant air flow and reading. I've chucked mine out and replaced it with a 3inch metal pipe. Heaps of difference in power and response.
You mean a metal pipe that is 2.5" at the factory turbo end and increases to 3"? Or are you not talking about a PU hiflow?
Something like this:
Edited by Harey
No mine has a 3" inlet
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
