cant be intake restrictions, 4" intake with K&N pod, 3" custom IC piping....motor was running standard turbo before and was pretty stock..
The car feels good, it has brand new 255 federals on the back and it breaks traction when it hits boost in second, used to do it in 3rd with the old tyres..
Heaps weird...
What ecu? No changes with fueling and timing makes you wonder if the changes are being written to the ecu.
Nistune was playing up like this on the Stagea last year with this sort of issue.
power fc... the changes were definitely writing because the wideband was registering the changes and the timing eventually caused the knock levels to increase slightly as well...
Hypergear turbos love restrictions :laugh:
I feel your pain though. Car has been sitting in the shed for a couple of months now, thinking about what it's done :glare:
Has it learnt its lesson yet?
Apparently not, it hasn't fixed itself yet. Now it's throwing a tantrum with the drivers seat, so it's in the naughty corner until I get back from Europe.
we both had no idea.... the car wasnt responding to anything... threw more timing= same power, richer=same power, leaner=same power wtf?
That means turbo's pushing some thing's limit which power band does not responds to the tune. I think its in the exhaust or some where, try drop it and see if any thing changes. Was it a plumb back external gate?
Normally cooler restrictions would drop heaps of boost, and the cooler would be burning hot on the cool side. So its not the case.
Also if you are in Sydney might be worth while visiting Toshi for a quick check up.
Why is the engine speed increasing then going back to zero? But speed increases gradually
I could be way off here but that torque looks quite high compared to power so maybe its getting wrong speed signal?
Rpm increases,decreases,increases then falls off
Edited by t_revz
yeah the dyno guy said that for some reason some nissans do that weird shit with the rpm... he said it wouldnt affect anything but.
The power graph really supprised me because it feels nothing like that...it actually has nothing for ages then all of a sudden kicks in massively and frys tyres but that graph makes it look very linear.... very strange
Just got off trents dyno
265rwkw with coil packs missing all over the place
19.7 psi down to 15.7 psi drop
Trent thinks it will hit close to 300rwkw once we sort out coilpacks and boost drop
Internal gate, note sure about the extended arm? Im guessing so.
Retune booked it for next Thursday.
Have purchased yellow jackets and will put in new spark plugs for the tune.
Trent made a suggestion that the boost drop maybe due to the stock BOV on the GTT not up to task? But were not 100% yet until I do the coilpacks and go back in for a retune.
Anyone know what the power limit on the stock BOV is before you need to be concerned?
He said to get a GTR one if it is the case.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
