this is very interesting. what sort of bottom end improvement could this yield on an RB26?
http://www.skylinesaustralia.com/forums/Rb...html&st=200
Some bloke gives away a secret if you read page 11. It has obviously been done but how and also how to do it reliably.
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-4496613
  • 2 years later...
This is interesting, any info on how to go about incorporating VCT into a 26?
Paul from Red R Racing has had something available for a while now having VCT on the RB26 head; simple and cost effective solution from what I have seen. One of his Stage 2 heads with VCT would be a total animal with the right turbo combination!
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6089968
  • 8 months later...
There was a more recent post on VCT for the RB26 head but I can't find it now. The link further back in this thread doesn't work. Does anyone have a chart showing the curve for an RB26 with VCT switched on and off to compare? It seems ERD and Red R Racing have developed a VCT system for the 26 - does anyone have prices for a completed head or for conversion of a supplied head? And is special ecu software required or will most aftermarket ecus such as Link/Vipec and Motec be able to run this OK?
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6450070
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=msg&attach_id=364854
That's the link to the dyno graph I PM'd someone here. The runs were done one after the other on 10psi boost on a bush bearing T04Z. We still hadn't done a larger inlet cam at this stage so the spec on the inlet side were roughly around the 245 deg advertised x 8.3mm lift. The car has a larger inlet cam in it now which has improved the response slightly but the wheels have changed since then too so I can't do a comparo from the baby cam to the new one
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6450089
The Green line is VCT off and Blue line is VCT on.
Also when the boost was increased to 30psi, the response gap between the two is larger. The VCT switching point should be just prior to the line intersection and it will follow the higher line but your tuner should know that already.
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6450290
The real world gains in advancing inlet camshaft timing at low to mid engine rpm far out ways the given gains in the displayed dyno graph but it does clearly shows the result of net losses if cam timing is left in the advanced position
https://www.sau.com.au/forums/topic/261777-rb26-vct/page/2/#findComment-6454097
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
