Just before I went for a quick drive, switched the car off for about 5 minutes, jumped back in and noticed the HICAS light is on solid and the car steers like a tank. A quick check of the steering belt and eveything seems fine (that is all I have had time to check so far as I am at work) but it's got me worried now, I just forked out a ton of cash to get it serviced and I'm hoping that it's not a major problem. I know nothing about the HICAS system. Really need help here.
1993 S1 R-33 GTS.
EDIT: Started car earlier and steering works fine again. Any ideas?
Edited by Stitch
  • Replies 92
Don't know about the heavy steering, sounds coincidental, but how many with their Hicas light coming on have an aftermarket steering wheel?
That's the problem I've seen. The machining on the boss isn't accurate enough, so the car thinks you're turning a never ending corner. Hicas computer eventually throws a fault.
Usually won't happen around town as you're continually turning corners, but a highway with long straight road is something else.
Hicas and power steering are related somehow, I got rid of the Hicas for this reason. Every time it rained my hicas light would come on and no power steering. Try replugging all the plugs on the hicas (near the diff) and power steering (under the bonnet) I used elec contact clearner and it worked untill it rained again.
You'll usually find it's due to too high resistence in wiring from age. The culprit is typically the front right earth strap to the engine from the body. Hence it's worse when it rains, same as coils and plug leads.
BUT, it's worth checking the health of your alternator and battery first, as if these are suspect it will also drop out.
  • 4 weeks later...
Just thought I'd update on my situation.
The power-steering fluid was topped up when I had the car serviced about two weeks before the issue begun, this raises suspicion.
I had my battery replaced with a much larger one just yesterday, this did not fix the issue.
I do have an after-market steering wheel fitted which has been in the car for over 3 years, would the problem take this long to develop as far as the steering wheel is concerned?
I have a can of contact cleaner, I will go crazy with it on the plugs and connectors tonight.
I have also attempted numerous times to get the car to go into diagnostic mode without success.
The issue does not appear to be weather related. Rain or shine the problem is still there.
The power-steering is definately affected by the HICAS. The power-steering works fine when starting the car in the morning, it is only if you turn the car off and then back on that the HICAS light comes on and the power-steering does not work at all. It seems you must turn the car off, leave it to sit for about 45 - 60 minutes before you are able to start it again without the HICAS/Power-steering failure. I think this piece of information would be key to working out what the problem is.
What is affected by leaving the car off? The only thing I can think of is its something heat related and I am by no means a mechanic so I might be being naive or missing something stupidly obvious. But that's what all you guys are for, right? :dry:
Thanks in advance
- Ben
Edited by Stitch
I went home last night and was ready to go mad with contact cleaner, but before I did it I started the car up after driving it home - no HICAS light. Went for a drive, turned the car off, turned it back on still no problem! This is strange as it would do it 100% of the time before. The car has now stopped and started 6 or 7 times in a row without the HICAS issue.
I'm thinking it may have been something to do with the battery after all, as this is the only thing I have changed since the problem began. The old battery didn't even have enough charge to push my power windows back up and they got stuck down, this is what prompted me to change the battery.
thats weird we're having the same exact problem....
i went through a phase where i'd turn it off and on and itll be okay but it stuffs up again...
have you got a turbo timer installed by any chance?
im trying to find the problem and honestly dont know where to begin.
Yeah, it is annoying! I had the autoelectrician look at it and when he saw the battery in it he scoffed. It was far too small for the Skyline, especially with all the electronic jazz they have going on. In hindsight it was pretty obvious but I never got around to doing anything about it.
At this stage I am only assuming that it is the battery, if it fails again I will post here.
1993 S1 R-33 GTS.
cheak your hicas fuse located under ur steering wheel, and to fix powersteering get a new cable!!!!!!!!.
Bahhhhhhhh!!!
this happened to me last night. it had rained, but nothing major.
this morning, power steering is fine again. when you removed the hicas junk off the diff and locked it, did this solve your problem?
my hicas light has been on for months now, but my powersteering has been fine. i highly suspect my steering position sensor is stuffed and that's what throws the light up in my case.
has anyone found a solution for this?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
