hey all
as some of you might of heard, in very unfortunate circumstances my sil caught on fire and melted a engine loom, and long and short of the short is it cracked a ring glan and then went down hill from there... so the poor lil 20's days are over :(
but from bad comes good....
and has finally given me a excuse to a RB25/30 :P
so here is what I have so far for the build...
(only started collecting parts only bout 1-2weeks ago)
- RB25 S2 Head
- RB25 Loom
- RB30 S3 Bottom end
- ACL Race Main Bearings
- ACL Rod Bearings
- ACL MLS Headgasket
- 2x Tomei Oil Restrictors
so this is now whats on the to get/do list:
- Boring, Blueprinting etc... on rb30 bottom end
- Arais Forged 20"tho Oversized pistons
- ACL Race Rings
- "x" Forged Rods
- Tomei Pro Cams (264 inlet, 272 exh)
- Stronger Value Springs
- ARP Head Stud Kit
- ARP Rod Bolts
- CNC billet rb30 crank collar
- assorted earls fittings and braided hose
- CNC Powertune RB30 Oil Power gearset
- Gates Timing Belt to suit 25/30 combo
- Custom Oil Drain
- New Water Pump
- Send my turbo back for the new one :D (GT3076R .84r)
- 50mm ext gate (currently running a KKR 38mm)
and thats all I can think of so far...
aiming to have the donk done by june-july... as there is a fair bit of coin right there haha!!
but 3 or so months anit long to wait :)
but if you have any suggestions fire away!!
cheers
Benji
Edited by Benji
https://www.sau.com.au/forums/topic/261976-benjis-new-donk-build-up-2530/
N1GTR: hitting the streets on permit that is, since mine is a track car!!! :P:(
I enjoy the old permits tho!!! its great fun!!
doing a CNC billet set of oil pump gears that are custom made to fit the std pump surround... but the gears itself are alot stronger and better..
and yes ill be doing a enlarged sump as well...(its similar to the high energy style ones)
and have had a chat to my engine builder and have decided to go with 40"thou oversized pistons, which brings it to 3.1ltr :laugh:!!!
and we are going to piss the vct off as well.. n run some tad smaller cams... and some adjustable cams gears as well
here is a pic of the car when it had the rb20 in it..
(mine is the blue s13.5)
Looks like a great build, i would recommend running an external oil pump, and dry sump it or rear sump it so you can lower the motor.
yeh i would love to run a ext oil pump but its the cash,
donk will fit in sweetly man... just wait and watch what im going to do when the time comes to slide it in...
nice car mate. i guess u drift it? cant go wrong with the rb30's for sliding my 2nd one is in progress aswell
awesome this means i will have 3.1 litres aswell. theres no replacement for displacement haha
yeh started to slide man, only been out 1 n a 1/4 times on the track
and was just starting to get a grip of things then the mis-happen of the engine loom melt down..
oh well now the power will be nice and responsive and will be easier to steer without having to be trying to bring it up on revs...
Edited by Benji
good work mate, i have been for 3 years now haha. i cooked a loom too when my engine blew and oil seal and caught fire on the track. you definately will have more response form the 30 vs the 20 it will be a big difference you will love it.
picked up ARP Headstud Kit today,
next week, the full forged SCAT rods, and 40" over sized Arais Pistons + Arais Rings,
Gates Belt Kit, and my Extended Sump... will be in :D
then after have got all them,
can start to put together the bottom end in the next few weeks
then we are away n cooking with gas :P yay!! : :hypo:
Also awaiting to hear back on the price of my Tomei Poncams + springs... (264deg inlet/exh),
once I know I can order away :)
so getting there at a steady rate now :P
  • 8 months later...
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
