Hi everyone. Just a short post to request the help of members and non-members alike for their assistance on the 18th of this month.
As some of you are aware, I will beofficially taken off the market by my better half on the 18th. What most of you probably don't know is that, apart from the swanky, pimp-spec stretch Jag, my other wedding cars are all 'lines.
Now this is gonna make for some really nice photos on the day but here's what i'd like to do if i can get enough people keen for the cruise to the gong on the Saturday in question.
Once all the usual photos have been taken, (Roger David/KMart catalogue poses etc), I'd like some shots with the cars (skylines) as far as the eye can see... Doesn't matter if they're 32's, 33's or 34's..... R's, S's or 4's etc.... Just that they're skylines and that they're the only things parked there !! :P
If you would like to help/be part of the day/have a sunny (hopefully) cruise to Wollongong, we'd LOVE TO HAVE YOU THERE. There may even be time for some naughtiness... :burnout:
Let me know guys n gals!
Best Wishes and Thanks in Advance,
Adrian & Taryn.
https://www.sau.com.au/forums/topic/26218-18th-of-oct-big-turnout-needed/
Thanks guys. Will need all the cars coming to be at an undisclosed location (prob either south or MM beach @ about 4 - 4:30pm on the 18th.
pretty much anyone can come along but the idea really is to get shots of just skylines. Any help is greatly appreciated.
Thanks for the response so far. Come on then? who else?!?!?
Adrian
:P
Bucks party was awesome... The mechanical bull turned up at about 10pm when everyone was sir-mashed and we all ended up bruised and battered.
Cowra Mark??? Talk about Bum-phark-no-where!!!
Adrian
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
