ok ok a question many have asked, but im sitll not satisfied
my car has around abouts 19kwrw, im running a BMC pod, now, im sorta getting sick of the sucking noise i get everytime i accelorate, not realy annoying but sorta want to get rid of it, so i am thinking of putting my air box back in, is there realy that much difference between the two? like, does the pod give so much more kwrw that it should be there? or does it do bugger all else that its not worth the sucking noise?
cheers
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/
Know what ya mean the standard turbo gets quite annoying with a POD
Standard Airbox fine imo, I was running 330ish rwkw with one (K&N panel filter as well of course). .
yea thats what i thought, i dotn see how the pod can be better apart from more exposure to air, with the snorkel to the from bar i dont see how its that bad, but i think the pod starts beating the air box at higher rpm? it can only suck so much air through the snorkel haha
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496145
Takes a lot of Air to flow 330rwkw cant be too restrictive, used to spin people out when they looked under the bonnet and it looked stock.
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496156
From what i've read, unless the pod is enclosed and thus is shielded from the hot air, it's actually detrimental to the cars performance.
My car had a pod when i bought it, i changed it back to stock air box. Didn't notice any difference. I agree that the pod is too noisy - i prefer the stock sound :P
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496294
x2. I put an Apexi pod into my 33.
Got sick of the noise pretty quick.
Changed back to stock airbox and Apexi panel and havnt looked back. Love the cute little spool noise the turbo makes.
And might i add, noticed no change in the way the car drives.
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496402
I don't wanna sound like a jerk towards you or anything, but you did do a search before you created this thread yes?
For your power you'd be fine with an airbox no worries. I have a pod, only because my cooler kit didn't accommodate for the air box, and it was easier swapping to a pod rather than butchering a perfectly fine item(the snorkel I mean). I have since boxed off the pod and routed a CAI and having the said annoying sucking noise which doesn't really bother me.
And if you feel a power difference between the 2, please report back with, "my car makes 11ty more bummerwatts" or "11ty less bum watts" because you won't feel a difference. And if you think you do......it's all in your head.
If your box fits back in ok, put it back in if it floats your floaty. And it's one less thing for a copper to whinge about. Win win :P
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496421
heh, yea i did a quick search, but i fail at finding words to search, "pod vs airbox" turned up bugger all, but yes, i think i will put the air box back in, i do also love that little whssssssssssss the turbo does when spooling hehe, even if im the only one that hears it :P
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496430
I have 200rwkw with a GT2530 turbo. I have the standard airbox and a pipercross panel filter. It is currently tuned to correct AFR's. These turbo's generally make 220-230rwkw's going by the results I've seen. There was a dip in the upper range of my power curve and it is annoying to know it could do better. We took the airbox snorkle, lid and filter off and I instantly gained 13rwkw. It doesn't sound like much and there was still a dip up high in the rev range. However, since the engine could breath better it must have started looking up another map section as the AFR's became rich in the dip section. If these were sorted out then it should hit the typical power figures.
If you actually take a good look at the snorkle and airbox lid they are pretty restrictive. You probably won't notice the lack of power changing from pod to airbox on the street as you aren't really driving high in the rev range which is where the most potential for improvement is. The other point is if you change something and don't tune it to suit it you won't know what affect it had on AFR's and whether there is more/less potential.
The less flow restriction (pressure drops) there are to the air going in and gases coming out the easier it is on the engine and turbo.
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496516
^ your intake pipe was most likely sucking close, can do that with that sort of power. look for 'rev210's intake pipe mod' or buy a silicone one.
as has been mentioned, stock airbox is fine, but you might need to get a silicone intake pipe to stop the 'sucking closed' issue
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496566
Thanks for the info. Unfortunately that's all been looked at. I did buy one of those silicone inlet pipes a while back but I don't really rate them. I don't want to start a war on that though, just my personal preference. I have a piece of stainless steel inside the rubber inlet pipe so it should not be sucking closed at all, pretty sure this was looked at as a cause anyway. I think this is what you mean by the rev210 mod?
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4496704
I agree that the snorkel could be improved. But, dyno with the bonnet 'up' isn't really worth anything as it negates the airpressure related position of the snorkel intake.
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4497037
Here's another option that could be adapted - paint it black to give it that OEM look:
and installed - note that the filter backs up against the back of the headlight to draw air in from outside of the engine bay:
Edited by juggernaut1
https://www.sau.com.au/forums/topic/262511-pod-vs-air-box/#findComment-4497242
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
