Thanks for your help much appreciated
I may have to have this one repaired until such time as I can replace it
It is annoying to have to spend money on something just to through it away in the near future
Thanks again
Phil
Wouldn't the radiator from the R33 fit?
If so;
http://www.mishimoto.com/nissan-skyline-r3...-mishimoto.html
(check boombop shop at eBay Motors for a much nicer price)
I have an Infinity G35 Mishimoto radiator for my M35.
VERY nice unit.
No trans cooler in them though, but you could just get either a Mishimoto or PWR trans cooler (I have both and will be running them in parallel).
I went to a NATRAD store and they fitted (pretty sure from an R33 auto series 2) a 5mm thicker Koyo aluminium radiator
works a charm, temps are now always low
black aluminium 22mm thick Koyo to suit r33 s2 auto
If so;
VERY nice unit.
and your trans gets bought up too temp how?
Transmission gets pretty warm on these things quite quickly.
It was my understanding that the transmission cooler in the radiator (bottom tank & surrounded by coolant) was there to help cool the transmission fluid.
But I read above that it is there to warm up the fluid?
What keeps the trans fluid from over-heating then?
Excuse my lack of knowledge, but "please explain"?
sure,
I spoke to RaceRadiators about a unit for my car, They told me best to stay with OEM, as the tube thru the rad brings it up to operating temp nice and quickly, and the small external trans-cooler is for stopping it for getting too hot.
sure,
Maybe I am a bit slow (a BIT??), but it still does not make sense to me.
The tube through the radiator has fins and is submerged in coolant. How does this "bring it up to temperature"?
I would have thought it would have kept it cooler...
the engine heats up quicker than the trans due to shit going boom inside it
LOL :wub:
That did come to me... later.
What about a manual trans then?
They generally don't have the tube going through the radiator, correct?
Edited by iamhe77
LOL :P
manuals dont require any form of cooling in street application from what i know
they also lack the tube thru the rad, so you can just use a justjap or similar alloy rad for 300bux
So how does the trans temp get up to operating temperature in a manual then?
Does it need to?
Why different to auto? Something to do with the torque converter I presume??
Sorry about all the q's, but if you don't know something...
Edited by iamhe77
I run a 50mm alloy radiator in the stagea (manual) but when I had my vl and the trimatic I never used the radiator to heat up the trany fluid that was with over 600hp. Every automatic street car I have had I have replaced the trans cooler with a larger unit if the radiator needed replacing then in went the biggest one without auto cooler in it. The fluid will heat up fast enough and the hotter it gets the more damage you do.
Here is the news
I went to a radiator place here in Ipswich he had a look at it and after telling him what I wanted to do with the car he sed that the standard radiator would do the job. He ordered the parts there on the spot and for $187.oo the job would be don tomorrow. All I have to do is pull it out (took all of 1hr) and put it back when it is finished. There just happens to be an auto place right next door so tomorrow when I have more time I will ask them about the auto line in the bottom tank and pass on the info.
Thanks
Phil
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
