  • Replies 615
Posted Images
I'm not a big fan of carbon clutches in a daily driver, their operating temperature window is too narrow. They slip like crazy until they get up to temperature. Even in a race car I have had one inexperienced guy kill one, just on and off the trailer and driving around the pits.
Cheers
Gary
<sigh>
Thanks for the heads up guys...
I've been through seven different twin plate clutches (and one triple) in my travels, some good, some bad, some excellent....
I thought I'd try something new, but after hearing the above reports, I'll stick with the tried and true OS Giken TS2CD. It'll be my THIRD one :)
At least it'll be a known quantity, but I miss out on trying new technology ;)
Thanks Baboo...
I'll stick with the known quantity OS Giken one for now, and consider trying a carbon one later down the track when I'm chasing extreme weight saving :)
Mark Berry, Russell Neuman, Mark Jacobsen and Paul Diemar use NPC twin plates.
Buy a real clutch Merli...not one that comes in a shiny box with fancy stickers.
I'll second the NPC. I've had it in the car for over 2 years and it's never slipped at the circuit or the drags and it's really easy to drive on even with the push/pull converter.
<sigh>
At least it'll be a known quantity, but I miss out on trying new technology :cool:
I have an OS Giken Twin Plate in my own R32GTST, I just service the plates regularly, just like brake pads they wear out. In the race cars we only use AP Clutches, 7" in the turbos and V8's and 4.5" in the 4 cylinders and rotaries. They are not cheap, but nothing good ever is. It's the combo road and track cars that I have the most problem with clutches, the compromises seem unavoidable. Either they are snappy and heavy for daily driving or can't handle track work or they wear out real fast. Depite many years of looking I haven't as yet found one that doesn't have at least one compromise.
Cheers
Gary
I've heard nothing but good things about NPC clutches, may try one down the track.
I use an OS twin plate which I just had rebuilt after doing this to it...
Lasted a long time though, and copped some fair abuse. I'm a big fan of it.
Twin plate Direct racing clutch, manufactured by "DIRECT CLUTCHES" here in Brisbane....great clutch and easy to use.
Had one in my STI for years of trouble free driving...recently tried the Excedy....worst clutch by far and after using it for the past 4 weeks, I will be getting the Direct clutch rebuilt.
I originally purchase the pictured clutch for the GTR....but after a test drive in AtomicBomberman (Chris) GTR, decided to give the carbon ATS clutch a go
ive used extreme single plates, os giken quad plate, direct clutch twin (older version) and a npc twin and the npc is the easiest to drive, handles 600rwhp drag launches time and time again, plus hard shifts with a dogbox and it is awesome to drive around town, the engagement is sooo smooth. The os qaud was an absolute pain to take off from lights etc i didnt like it one bit.
NPC twin is $2000 from memory, these are cheap as to rebuild as well unlike the os giken ones, definately top notch. My twin plate is bigger than the quad plate, its definately a serious piece of workmanship.
$2400 retail...a little cheaper for trade
ARP flywheel bolts $110 retail...again a little cheaper for trade.
Edited by DiRTgarage
thats a sprung centre one, mines a solid centre and still a treat to drive, they are absolutely huge for a twin plate too
ive never had to drop the engine xmember to put box in either, just tip the motor right back and ya fine.
Edited by unique1
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
