  • Replies 615
Posted Images
I'm not a big fan of carbon clutches in a daily driver, their operating temperature window is too narrow. They slip like crazy until they get up to temperature. Even in a race car I have had one inexperienced guy kill one, just on and off the trailer and driving around the pits.
Cheers
Gary
<sigh>
Thanks for the heads up guys...
I've been through seven different twin plate clutches (and one triple) in my travels, some good, some bad, some excellent....
I thought I'd try something new, but after hearing the above reports, I'll stick with the tried and true OS Giken TS2CD. It'll be my THIRD one :)
At least it'll be a known quantity, but I miss out on trying new technology ;)
Thanks Baboo...
I'll stick with the known quantity OS Giken one for now, and consider trying a carbon one later down the track when I'm chasing extreme weight saving :)
Mark Berry, Russell Neuman, Mark Jacobsen and Paul Diemar use NPC twin plates.
Buy a real clutch Merli...not one that comes in a shiny box with fancy stickers.
I'll second the NPC. I've had it in the car for over 2 years and it's never slipped at the circuit or the drags and it's really easy to drive on even with the push/pull converter.
<sigh>
At least it'll be a known quantity, but I miss out on trying new technology :cool:
I have an OS Giken Twin Plate in my own R32GTST, I just service the plates regularly, just like brake pads they wear out. In the race cars we only use AP Clutches, 7" in the turbos and V8's and 4.5" in the 4 cylinders and rotaries. They are not cheap, but nothing good ever is. It's the combo road and track cars that I have the most problem with clutches, the compromises seem unavoidable. Either they are snappy and heavy for daily driving or can't handle track work or they wear out real fast. Depite many years of looking I haven't as yet found one that doesn't have at least one compromise.
Cheers
Gary
I've heard nothing but good things about NPC clutches, may try one down the track.
I use an OS twin plate which I just had rebuilt after doing this to it...
Lasted a long time though, and copped some fair abuse. I'm a big fan of it.
Twin plate Direct racing clutch, manufactured by "DIRECT CLUTCHES" here in Brisbane....great clutch and easy to use.
Had one in my STI for years of trouble free driving...recently tried the Excedy....worst clutch by far and after using it for the past 4 weeks, I will be getting the Direct clutch rebuilt.
I originally purchase the pictured clutch for the GTR....but after a test drive in AtomicBomberman (Chris) GTR, decided to give the carbon ATS clutch a go
ive used extreme single plates, os giken quad plate, direct clutch twin (older version) and a npc twin and the npc is the easiest to drive, handles 600rwhp drag launches time and time again, plus hard shifts with a dogbox and it is awesome to drive around town, the engagement is sooo smooth. The os qaud was an absolute pain to take off from lights etc i didnt like it one bit.
NPC twin is $2000 from memory, these are cheap as to rebuild as well unlike the os giken ones, definately top notch. My twin plate is bigger than the quad plate, its definately a serious piece of workmanship.
$2400 retail...a little cheaper for trade
ARP flywheel bolts $110 retail...again a little cheaper for trade.
Edited by DiRTgarage
thats a sprung centre one, mines a solid centre and still a treat to drive, they are absolutely huge for a twin plate too
ive never had to drop the engine xmember to put box in either, just tip the motor right back and ya fine.
Edited by unique1
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
