im always up for tips on how to reduce lag, and recently saw a dyno graph with a gt55 turbo on a supra which had a curve like it was a t04z.
the supra was stroked to 3.4L and some nice cams but he also mentioned that half the reason why the spool was so insane was because he had a "spool valve"
from wat i understand its basically using a split pulse manifold system and blocking off one side to force the exhaust cases through the other one. resulting in more restriction thus faster PSI buildup.
any professionals care to explain this tatic any any pros and cons?
honestly never heard about it until now
btw does anyone actually sell these in aust?
Edited by VB-
https://www.sau.com.au/forums/topic/264645-spool-valves/
I see thread pop up about this every few months on other boards. I've never actaully seen anybody use it other than that one write up with the Supra, but it requires a NON-split pulse/twin scroll manifold to work. It's interesting for sure, but I've got a split pulse manifold, so I'm not going to be a guinea pig. How much do they cost?
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4523705
I don't see how this would be effective at spooling a turbo any faster. Basically this would create more pressure on the manifold side of this valve as the exhaust gasses try and pass trough what is a smaller opening and as i have been taught increased pressure does not increase flow through the same sized hole.
Basically this is choking your exhaust. The best way to spool a turbo is to get as much exhaust gas onto that turbine wheel as soon as possible. Putting a restriction like this in place i can't see how it would work as you are basically halving your exhaust flow with the restriction like that in place...
use this calculator ( http://www.efunda.com/formulae/fluids/calc...iction.cfm#calc ) to see that increasing the pressure without changing the pipe diameter does not alter flow at all. change the pipe diameter however and watch the flow increase.
I wouuld say that there would be a optimal size in exhaust header diameter to keep flow and gas velocity at an optimal level.. but to my mind a contraption like this wouldn't help.
My two cents, hope it helps.
Not to mention companies like HKS/GARRETT etc probably don't make these and that would be a fairly good indication as to whether they work or not.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524082
It would work by accerlating the gas flow into the turbine at low revs. so instead of having a large area of slow moving gasses they have a smaller area of high speed gasses.
I could work in theroy but without having serveral diffenent cars with it to back up the results its all hersay.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524108
The fact that they could improve spool etc definitely makes sense - its effectively like hugely tightening up the turbine a/r, though ultimately I don't like them - they would make the breathing of the engine very inconsistant and even when its open I really can't see it doing anything other than creating a restriction. All the dyno plots I have seen with hem being used seem to finish at the point the "normal" setup catches up... what happens to top end flow?
There may be a better way of doing the same kind of thing.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524149
i agree with lithium, causing a restriction would basicly rack up psi way faster.
as far as top end, i dont know how this would be possible due to restriction. but they claim it gives a 25% INCREASE in top end and improved spool.
if i can get my hands on one id defiantly be interested in trying it out.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524220
It effectivly halves your a/r then opens up at a certain psi when the turbo is well on it's way to being spooled. It's kind of like a poor man's variable geometry turbo. I'd be worried about it standing up to high temps. I have no doubt it works, but how well and at what cost/pain in the butt are my questions.
And basing whether or not something works off of whether or not HKS or Garrett makes it is rediculous.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524309
I did once see a diagram of something along those lines but I smell marketing rather than function driving this idea .
Firstly to have it work properly you'd need an open collector manifold with that thing between the manifolds mounting flange and the twin scroll turbine housing .
What it does is feed all the engines exhaust gas through one side of the divided turbine housing until the plates throttle opens up .
I image once the boost , or preferably the exhaust manifold , pressure reaches a set point the actuator opens the throttle valve .
The downside is that the throttled side won't flow as well as the open side and the open collector manifold won't work like a true twin scroll system .
I think a 3.4L 2JZ type thing should not have dramas making torque off boost or kicking a big turbo into life if the manifold/gates and the overall state of tune is on the money .
Gimmick I think , cheers A .
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524621
oh that and they are 500usd for a t4 flange.. a guy on ebay made some the SAME for $100 but got sued by sound performance coz they have a patent pending on it...
evan though borg warner patented the concept using a valve in the actual turbine housing....lol
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524719
$500 isn't too bad if it works I guess. Holset does the same kind of thing with variable vanes in the exhaust housing effectively changing the a/r. It makes a 600rwhp turbo spool like a stock turbo, but the problem is it's electronically controlled via the factory Dodge ECU and people have yet to make it work real well in a non-OEM application.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4524842
It's already been around for a couple years. I think they were having some kind of "development problems" which is why they put the idea out there, but didn't sell it yet. Maybe making it last on high hp daily driven cars is still a big hurdle.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525225
Hmm interesting idea, never come across it before. However when its fully open, surely the side with the valve in it would be at a greater restriction than the other side causing a larger pressure build up in the runners for cylinders 4, 5 and 6. This wouldn't have a slight negative effect?
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525235
you would think so huh?
but they claim it would ACTUALLY increase top end by 25%.......dunno how but insane if true.
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525307
Obviously you would have to run a normal (non split pulse) manifold, and a split pulse turbine housing ....... when closed all the exhaust gas is re-directed thru one side, generally 1/2 A/R of total housing rating. So spool up would be same as a much smaller housing, and top end of the larger housing. There would be a slight restriction to the runner with the plate in it obviously, and so i would say power could be slightly lower , top end. Depends on how hard the housing is working to make the power you are at.
As i mentioned , this was a factory setup on the S4 Rx-7. It however , used a setup more akin to a wastegate flap, not a butterfly.
I wonder what materials they used, as that flap looks quite thin. You'd think there could be probs with it sticking too with the huge heat range it would be getting.
Gary
https://www.sau.com.au/forums/topic/264645-spool-valves/#findComment-4525393
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
