hi guys,
im looking at purchasing cams from http://www.camtechcams.com.au/ & valve springs from http://www.performancesprings.com.au/.
pricing has attracted me & i've heard some good things about both products to date, im also aware that some engine builders use these brands.
how do they rate in terms of quality & performance versus the likes say jun, hks, tomei?
regards
marko
https://www.sau.com.au/forums/topic/264697-aust-made-cams-valve-springs/
  • Replies 77
Marko you need to put "ill keep racing but" in the approprate spot in the quote in your sig.
haha - thats true paul, that should be added on the end of jims quote...
Get your $900 and buy Australian made, good on ya!
i wonder if they stamp the cams with the green & gold "STRAAAALIAN MAAADE" sticker lol
Haven't delt with camtech but I have been running performance valve springs for about 10-15 years in a variety of v8's including full on drag engines spinning to 11000 rpm, have not had an issue with any of their products they are top shelf,I would recommend their product to anyone!
i spoke to the camtech rep today as they now offer 270, 278 and 280 duration @ 10.8mm lift
with the 11.5mm lift i was told that more work is required to the head and that the factory buckets can become unstable
what would be the better option for increased performance?
marko, better off not to go too big on camshafts if you are running -10's, otherwise you will make it abit of a lag monster... keep them suttle and not 2 big, look at the group a aussie gtr's, they had medium sized cams and produced 600+ brake with a rev limit of 7000rpm. the porting is the most important in making power...
by the way, your setup will piss in 400rwkw.... u stress 2 much
i know dennis - im hopeless when it comes to making decisions!
i understand your point BUT remember that im doing an rb26/30 which means i can afford to go a bit bigger with cams...i was thinking the 270degree @ 10.8mm lift would be ideal?
what cams u running in your built rb26?
dont forget my 26 was to be a drag engine, with 9200rpm limit... i had hks 272 with 10.2 lift... these cams would be well good to go to 9500rpm...
my 32 gtr has gibson group a cams, same as in the bathurst gtr's, i have -10 on that engine also, these cams will be a shitload better for drivability, thaink about it, if the bathurst gtr's used them they would have had one thing in mind, "torque" and still produced big numbers, and they were 26's not 30's, remember torque is what u want, if u focus on achiving this your car will be a animal....
from what ive found - these are the cam specs of the gibson m/s gtr:
Inlet 256 @ 9.5mm lift
Exhaust 278 @ 9.75 mm lift
for a 3ltr though, i'd need to go bigger 1 would think
a few tuners had recommended 270-272 with under 11mm lift, i'll probably stick to that unless i hear of better results from smaller cams, its hard to know...all trial & error if nobody else has tested bigger v's smaller cams
I'm running a pair of 264 [email protected] 9mm (110/115) cams at their std centrelines in the rb30det with a 9:1 static comp, ported/polished, deshrouded head.
Idles smooth and can tell its got a slight cam but doesn't lope as such. Just a deep smooth throb.
The top end has that typical cam sound due to the increased ramp rates.
Economy is great (attributed to a slightly better tune) and picked up ~30rwkw on the same boost.
No noticeable seat of the pants low end loss (dyno shows real slight loss under ~2000) but once over it starts making more power everywhere.
For the RB30DET RB25 head I'd personally convert to solid and run 10.5mm lift cams otherwise you have to try and screw too much boost in to it to make decent power (350-400rwkw+) on pump fuel. Pump fuel really doesn't like lots and lots of boost. :D
Edited by TheRogue
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
