  • Replies 104
Pm's replied.
Selling wheels & tires for $450. For those of you that requested close up photos here they are;
Tyres on rear are pratically brand new Achilles ATR Sport 225/45/ZR17
Fronts are Linglong L688 225/45/ZR17, still with legal amount of tread.
Edited by DRFT31
Hey guys just thought ill give use a quick update, the parts below are sold;
R34 rims, L & R Mirrors,Indicator stalks,a/c controler,center console,s badge, complete rear badges,double din console,plastic surrounding around double din console, 3 guage cluster,traction control switch,drivers side coin pocket, horns, headlight aimer switch, center ashtray next to gearstick.
Everything else still available. So just pm me with your offers.
Front pipe is a 3inch mandrel bent mild steal pipe straight off turbo to cat $200
3inch High Flow stainless steel cat with flanges $160
Front seats $300
Original Nissan Aero/Nismo Plastic Lip not cheap fiberglass, with small cracks. Very rare will fit both on standard coupe/sedan front bars. $175
Front Bar with turbo vent, does have small holes where Nissan have cut to attach lip $175
Standard Smic, minus piping $200
Rear boot carpet $100 excellent condition
Xennon Headlights im after $1600 firm they are in excellent condition, nissan have quoted me $3000 each when i was after a pair.
Bonnet $250ono
Left and right doors, Front quarter panels both in good condition still available
Just pm me with any questions.
Cheers.
Edited by DRFT31
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
