I've got a non-ABS S13 with R34 GT-t brakes all-round, and am obviously lacking an adequate BMC. I love a very firm pedal, so bigger is better for me - Logical option, BM57 (1 1/16")
As far as I can tell, these were only made for ABS use, thus will have 2 outputs.. With me needing 3.
Can anyone shed some light as to my options? Looking at an R33 ABS BMC, it appears there is a blank face where the third line would go - can this be tapped and run like normal?
Can I just run a T piece out of the one front line output?
Google has failed me on this one, so I need some help :(
Also - can anyone tell me what BMC the R34 GT-ts use? I found the info for every model BUT the 34GTT.
Thanks!
-Luke
https://www.sau.com.au/forums/topic/265245-bm57-non-abs/
With the help of Wing, we have come to a few conclusions thus far;
- all BM57s are 2port only
- they have the 3rd port there as a blank
- proportioning is the same between ABS and non-ABS
Now, I need to FIND a BM57.. Then I have to work out if I will drill and tap, or add a T piece.
https://www.sau.com.au/forums/topic/265245-bm57-non-abs/#findComment-4536459
Add a T peice to the front line.
You cant drill and tap the fitting as there is a flare seal on the inside of the master that the line needs to seal on. You could use a banjo bolt but a t peice will work just fine.
The proportioning valve in a BM57 will work fine with the brakes that you have Luke.
However 1 and 1/16ths is too big.
A firm hard pedal does not always mean better stopping. You'd have a slightly softer pedal but much better brake modulation with a 1 inch tandem master.
https://www.sau.com.au/forums/topic/265245-bm57-non-abs/#findComment-4537035
